Go to Post Getting that degree is the reason for going to college. Failing out of school because you mentored isn't really a good reason. - [more]
Unread 14-03-2010, 11:11
Re: Caution - Burned out CIM blows Victor
Originally Posted by JesseK View Post
Interesting information. I wonder how the jags respond to this, given their internal fault protections. Really I just want to know so if something weird happens electrically we don't immediately blame the Jaguar.
There is really only one way to find out, and due to the RMA policy, it is free.
To measure CIM resistance, you really need a 4 wire set up and you need to check across the range of shaft positions. Hook up the 4 wire resistance meter and SLOWLY turn the shaft in small degree increments, pausing for a few seconds each time. The brushes can easily double / halve (or more) the resistance for a given position, and the back emf (generator voltage) of a moving CIM will overwhelm the ohmmeter.
Burned out 2 5V regulators on Power Distribution boards jskene Electrical 5 13-02-2009 11:17
[FTC]: Caution - Tetrix Motors burn out on Stall ptan FIRST Tech Challenge 3 11-02-2009 10:19
Victor lights out of sequence matt99199 Electrical 4 10-02-2009 10:11
Wiring 2 CIM motors to one Victor ericsundbergva Motors 2 18-02-2008 10:12
Anybody else burned out? PMGRACER General Forum 52 18-01-2004 19:14
