Go to Post My wife thought the lead singer, Ozzy Kamen was cute. Darn those rockers. - Andy Baker [more]
Unread 14-03-2010, 11:06
greatman05 greatman05 is offline
AKA: Chavez Clemons Jr.
FRC #2224 (Phoenix Phenoms)
greatman05 is an unknown quantity at this point
Send a message via AIM to greatman05 Send a message via MSN to greatman05 Send a message via Yahoo to greatman05
Question Autonomous using camera?
Hello. My team wants to have an autonomous mode where the robot searches for a ball, runs to it, searches for a target, and then kicks it. I have no idea how to do this, since I have no experience in vision processing whatsoever. I read the NI tutorial on vision processing, but I really don't understand it. Also,
what components do I need to have besides the camera for something like this to work?
Unread 14-03-2010, 11:23
Re: Autonomous using camera?
The default project contained some of this code, the stuff to identify and rotate to face the target. There have been some discussions about finding the balls using the camera, but the default code doesn't implement it. In fact, it is likely that the camera mount will not be able to see the ball and target at the same time. You may want to look for other ways of locating a ball as well.
Greg McKaskle
Unread 16-03-2010, 10:07
Well then, what are those methods? I'm completely unsure as to how to approach this.
Unread 16-03-2010, 11:03
You can place your robot and your balls in known locations. The autonomous program doesn't need to seek out a ball if it can assume a ball is in a specific spot. All you need to do is drive the robot to that spot consistently.
Using Sensors in Autonomous Independent Felipe Sagui NI LabVIEW 2 27-01-2009 17:25
CODE: Using the gyro in autonomous Kingofl337 Programming 1 20-01-2008 19:11
multiple autonomous modes using easyc cerberus170 Programming 3 20-02-2007 15:01
Autonomous using encoders Mr.G Programming 11 17-01-2006 03:34
Using REAL ENGLISH in autonomous mode??? RIgnazio Programming 14 17-02-2005 17:19
