Go to Post The phrase "Gracious Professionalism" is being thrown around much too often to try to support anything and everything that a certain individual feels is unjust. - Neo3One3 [more]
Unread 03-14-2010, 02:43 PM
Re: Watchdog not fed
All loops in the LV framework delay either until an occurrence is sent or for a timed amount. If you do not put a delay into a loop, you are informing the compiler and scheduler that it must run as fast a resources allow, which is often way faster than you need. The way to tell it how fast you need is to put in either a time delay or a notifier.
Since it isn't obvious, the LV framework suspends inside the Get Mode subVI waiting for the next packet to arrive. It does this using the Wait for Occurrence primitive. That is why no waits are inside the Robot Main loop.
Greg McKaskle
"watchdog not fed" error Lumit NI LabVIEW 8 02-04-2010 06:45 PM
Watchdog Not Fed but, All Systems Are Go. DHSrobotics Java 4 01-24-2010 10:01 PM
Watchdog not fed ahudson Programming 1 01-22-2010 11:26 AM
Fed Ex Airbill Troubles Eric Reed General Forum 12 02-19-2007 02:31 PM
fed-ex shipping question brennerator General Forum 2 03-23-2005 07:09 AM
