Go to Post You know you're addicted to FIRST when...You relabled the speedometer in your parents car so that 0 is 127 - Sharkbyte [more]
Unread 14-03-2010, 13:47
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
The 469 auto
So it looks like team 33 is going to be at the next two compitions with 469
I was just wondering if something like this was aloud for the starting position.
[R B B ]
| B B |
| BR B |
| B B |
| TT RTT |
| B B |
| R B B |
| B B R|
[ B B ]
TT = tower/tunnel
B = Bump
[ = goal
R = robot
The robot in question would have their right front wheel touching the bump and they would not not start across the line. Then when auto starts they would drive straight into the tunnel at an angle wedgeing their front right side under so they could not be pushed out.
Close up of robot position after auto (top view)
R
R R
R RTTTTTTTTTTTTTTTTTTTTTTT
R TR T
R T R T
R T R T
R T R T
-------------------- T----- R--------------------T------
S T R T
S S T R T
S S T R T
S T T
S RTTTTTTTTTTTTTTTTTTTTTTT
S R
S
S
S
- = middle line
R = robot's position after auto
T = tower/tunnel
S = robot's starting position before auto
Would this be a solution to 469?
Your thoughts?
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 14-03-2010, 13:54
JABot67 JABot67 is offline
Unregistered User
AKA: John Bottenberg
FRC #2930 (Sonic Squirrels)
JABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond repute
Re: The 469 auto
I'd like to understand your auton strategy, but it looks like your post got all messed up. Perhaps CD does not like too many spaces in a row. Try using the code tags, like this:
Insert         Field          Here
John Bottenberg - University of Michigan '14 - Microsoft
FLL Team "Dark Matter": 2003-2005
Robofest Team "Dark Matter": 2005-2008
Team 67 Programmer: 2007-2010
Team 3322 Programming Mentor: 2012-2014
Team 2930 Engineering Mentor: 2015-????
Unread 14-03-2010, 13:55
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Re: The 469 auto
Aaaaaaaw it did...
that stinks ill redraw it in paint...
Unread 14-03-2010, 14:08
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Re: The 469 auto
Ok I fixed ithttp://question
I hope this works
Unread 14-03-2010, 14:19
Unregistered User
Re: The 469 auto
The link doesn't work.
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: The 469 auto
link still doesn't work...
469's strategy is brilliant, because in order to stop them you have to not only prevent them from getting to the tower first, but you also have to camp there the whole match so they never can get there, since once they're in position you really can't get them out. So while you're keeping them from getting to the tower they're free to do whatever they want. And you have to move out of the way in the last 20 second, or you'll get a penalty for contacting the opponent's tower...pretty beastly strategy, I can't wait to see video of them.
Unread 14-03-2010, 14:20
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Re: The 469 auto
AAAAAAAAAAARRRRRRRRRRRGGGGGGGGGGG
Ok, basicly, line up on a 45 degree angle to the opponents tower with your front right wheel / side of your robot touching the bump right next to the tower. Then when auto starts your robot would drive straight into the tunnel on a 45 degree angle effectivly wedgeing the front right side of your robot under the tunnel so 469 can't be there. Because you are so close to the tunnel 469 couldn't beat you there even if they charged there without shooting their balls first.
Sorry about the not working picture / link
Unread 14-03-2010, 14:35
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Re: The 469 auto
I don't think you would even have to move. Can't you pretty much block tunnel edge just by the placement of bot? This was tried but the bot doing the blocking didn't have traction and was pushed out of way. I think the idea of blocking is good but not the whole package. It will only throw their game off alittle. You will need good team mates, playing in the right positions. Man, Troy is going to be fun.
Unread 14-03-2010, 14:38
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Re: The 469 auto
ya I realize that but lets say for instance 33, 910 and some other team was on an alliance against 469, 217 and some other team.
Senerio one: A effectivly a 3 on 1 with the third team to block/pin well 469 recycles balls and 217 puts in the misses. The other two teams try to keep up with them on the other side of the field but undoubtly fail, they can't keep up with a ball every 4 to 5 seconds.
Senerio two: In the beggining of the match our third team wedges themselves under the tower. Then team 33 now has a fighting chance for the balls in the middle. 469 has dificulty turning. However 217 is still a huge threat. 33 is now playing a 1 on 2 tring to shoot balls down to 910 to to score. We have to count on 910 ten being able to beat the defense and 33 quickly passing balls down. Overall, its not looking good.
ps. The reason I use these teams is because this is a realistic possibility at Troy in week 4.
Senerio
Unread 14-03-2010, 14:51
FRC #0910
Re: The 469 auto
Did anyone have a bot at Cass that could redirect the balls back into middle after the balls rolled off 469? Was this even tried or is the ball to low coming off 469 to send it back over bump?
Unread 14-03-2010, 16:00
JGurnow's Avatar
JGurnow JGurnow is offline
FRC #0217 (The Thunder Chickens)
JGurnow is on a distinguished road
Re: The 469 auto
The balls are below the bump when the balls leave contact with their robot. You need to intercept the ball and kick it away to stop the strategy. Another team tried hitting the tower as the balls were coming down and that doesn't stop balls from being scoring.
Its a very good strategy, stop 469 and the match is 3v2, don't stop them and you can't outscore them.
469 has no problems pushing robots out of the way. It has obscene grip and is geared low to push anything out of the way. They can push and turn opposing robots with the bests of them.
Unread 14-03-2010, 17:44
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: The 469 auto
Notes on 469's drivetrain:
8wd with pneumatic tires, 4 CIM through DW trans, I don't know the exact gearing.
Pneumatic articulated Front and Rear wheels (I don't think separately)
Pneumatic articulated ball casters in rear.
No ability to change zones (I guess they could go over the bump, but that probably wouldn't end well with that tower on top)
Pneumatic lock to tower - It locks to the bottom of the tower. They aren't just shoved in the tunnel, they are locked there. They aren't coming out once they get in, at all.
*should* turn well with outer wheels up
Autonomous start positions:
---------------------[OUR TOWER]----------------------
                                   [their robot]
                [Our robot]
--------------------[THEIR TOWER]----------------------
We can get to their tower before they can, if we can do it in Autonomous. Then they would be stuck playing a regular game, without recycling balls. I didn't get a good look at their ball-o-fier or kicker, but both exist and are capable of acquiring and kicking a ball.
Kettering Motorsports
Unread 14-03-2010, 17:59
Chris is me's Avatar
AKA: Pinecone
Re: The 469 auto
If the balls are below the bump, then they're coming out under the Bumper Perimeter...
Unread 14-03-2010, 18:24
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: The 469 auto
I think he meant to say that the balls are below the bump when they leave the tower/bump area. Looks like they guide them down onto the back side of the bump to deflect them horizontally and eliminate bouncing.
Unread 14-03-2010, 18:27
AKA: Pinecone
Re: The 469 auto
In which case, you could have one defender in the zone and a second resting on the bump to stop transfers on one side.
Using auto cad for the autodesk inventor competition [527]phil Inventor 7 18-01-2006 10:41
Creater of the DeLorean auto dies Jay H 237 Chit-Chat 4 23-03-2005 12:54
Ruling for what defines being at the auto-loader Andrew Schuetze Rules/Strategy 4 15-01-2005 22:41
Team 469 and the Gyro archiver 2001 0 24-06-2002 02:57
Team 469 is the coolest!!! yystickers Off-Season Events 0 19-11-2001 14:51
