Re: Rule against Sirens?
We use a rumble pak that vibrates when we grab a ball. That doesnt make much noise and gets the drivers attention (they never look at LEDs). We used the rumble pack last year to indicate when our turret sees the target. I have heard other teams use them as well (not sure who). Rumble paks are easy to reverse engineer to work with a digital out (heck if convicts can figure out how to make tattoo guns with them, then it shouldn't be too difficult for a young engineer).
I will not say anything about safe noise levels (no one would take me seriously coming from a team that got loud noisemakers banned ). However, I believe audio cues should be taken from the coach only, not the control system.Last edited by The Lucas : 14-03-2010 at 19:45. |
-Tanner |
My team (33) is using big LEDs to let the drivers know when something important just happened.
LEDs blue = ball possessed LEDs green = lined up with a goal LEDs red = latched onto tower and ready to hang The last two were not functional at Kettering but will be at Troy I think LEDs are the way to go because you can use them for multible functions. Although it does alert the other teams to our current scoring abillty ... Oh well well be getting hit anyway![]() |
We have one of these buzzers mounted in the center of our DS
http://www.radioshack.com/product/in...ductId=2062394 It turns on whenever we have a ball in our possession. As a driver, I can say that it is tremendously helpful and has definitely improved our performance. Panel indicators and LEDs aren't nearly as good because they require the driver to look at something other than the robot, or at least interpret slightly more visual data. I think that its quite a stretch to suggest that an intermittent buzzer of reasonable volume is going to bother your team mates in the middle of a supercharged match with music blaring and people cheering all around them. Edit: I'm going to go ahead and recommend that specific buzzer from radioshack. Even though ours is just something someone happened to have, it looks just like that. It draws 15ma on 3.3 Volts, so you'll have to use one of the high current digital outputs. Hook the negative wire from the buzzer to the digital out so that a logic low turns it on-- the outputs can sink more current than they can source. Last edited by sparrowkc : 14-03-2010 at 20:35. |
Sorry if I wasn't clear
The big LEDs are on the robot and very visible. |
BJC, they are automotive cold-cathodes. They are also very large, 12" long tubes, compared to LED's. We are powering them via Spikes on a dedicated 12v 20amp breaker, so no 3.3v DIO's here.
#7
By using the can bus on our jaguars we can monitor the current our vaccum is drawing and trigger the vibration motors when the current drops (when we have a ball in our possession). As a driver its particularly helpful when going for the balls that are against the bump nearest to me, which I can barely see. |
#8
Driver should be looking at the robot, so we put a light on the robot, activated by a vacuum switch on our ball sucker.
Vacuum switch is fairly inexpensive, and commonly used on high efficiency home furnaces. |
| My case against <G14> | bduddy | General Forum | 58 | 07-01-2009 15:20 |
| Against all odds... | ForgottenSalad | General Forum | 14 | 31-03-2007 17:43 |
| Unsportsmanlike conduct. 3 against 1 | angryyoungnpoor | General Forum | 16 | 14-03-2004 08:42 |
| Rule G11 and Springs Rule | mtaman02 | Technical Discussion | 3 | 23-01-2004 17:43 |
| Can we use sirens on the robot? | intx13 | Rules/Strategy | 14 | 18-01-2004 19:17 |
