Go to Post The world isn't changed by people playing it safe. - Andrew Y. [more]
Unread 14-03-2010, 18:18
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Rule against Sirens?
Good evening, CD!
I just picked up a RadioShack 273-079 12VDC Piezo Siren from (guess where) RadioShack, in hopes to integrate it into our DS. After hooking it up to a supply, I have come to realize that this siren is VERY loud. This is ideal for a competition setting, as it will certainly get the driver's attention. My question is, are there any rules against creating noise from your DS (or robot for that matter)? I did a quick skim over the rules again, and couldn't find anything, but wanted to make sure.
Also, is there anyway to control volume for a piezo buzzer? Something tells me no (I've tried varying voltage with no avail), but I figured I'd ask.
Thanks!
Jacob
EDIT: after reading, it looks like maybe I can use PWM to control the volume.
Unread 14-03-2010, 18:31
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: Rule against Sirens?
i would say dont do it
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 14-03-2010, 18:35
102db is well up into the "unsafe for your hearing" levels. If you can't mute it go find something quieter. You are likely to be disqualified for operating a robot that creates an unsafe environment for people. (I didn't bother looking up the rule number. If there isn't a rule against it, it's still wrong -- it shouldn't pass inspection, and a referee should DQ it should it appear on the field.)
Not that the music at some venues doesn't exceed 100db, but that's another perennial thread that I expect will show up soon.
Unread 14-03-2010, 18:55
Controlling the volume is easy. Just put it in a box. Close the box for quiet, and open the box for loud. Add padding around it to muffle it effectively.
Unread 14-03-2010, 18:56
AKA: Jacob Komar
Thanks for the responses. I guess my question now is, if I can find a quieter siren (80 dB or so), is there a rule that prohibits the use of this on the DS?
Thanks
Jacob
Unread 14-03-2010, 19:29
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
I'd advise against a buzzer... i dont know of any rules specifically against it, but i know that you cant have any sound systems on the cart.. It may be distracting to other drivers
Unread 14-03-2010, 19:32
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
If you plan on using it on the driver station, you'll have to keep in mind that the DS only outputs 3.3V (I think).
I wouldn't recommend it, though I would say if you find one quiet enough to be heard it'd be ok. I think it would overall be better to have your programmer put something on the Dashboard and have the coach/driver take a looksie at it now and then. Or a giant light.
Being a driver and one who is very jumpy (ask anyone on my team), I wouldn't like it very much if I got scared during a match.
-Tanner
Unread 14-03-2010, 19:41
The Lucas's Avatar
CaMOElot, it is a silly place
We use a rumble pak that vibrates when we grab a ball. That doesnt make much noise and gets the drivers attention (they never look at LEDs). We used the rumble pack last year to indicate when our turret sees the target. I have heard other teams use them as well (not sure who). Rumble paks are easy to reverse engineer to work with a digital out (heck if convicts can figure out how to make tattoo guns with them, then it shouldn't be too difficult for a young engineer).
I will not say anything about safe noise levels (no one would take me seriously coming from a team that got loud noisemakers banned ). However, I believe audio cues should be taken from the coach only, not the control system.
Robot Inspector
Unread 14-03-2010, 19:42
AKA: Jacob Komar
We have a 12V supply on our DS, which is the regulated to feed our USB hub among other custom circuits. I have installed a light that is triggered by the same function that the buzzer would be triggered by, it's just a very worst-case scenario type of thing that requires immediate attention (things breaking themselves, essentially an indicator to hit the E-Stop). Following Alan's suggestion, I've padded the siren, and now it's very moderate.
Thanks everyone,
Jacob
Unread 14-03-2010, 19:43
Tanner's Avatar
That's pretty creative. I would have never thought of that. Awesome.
-Tanner
Unread 14-03-2010, 19:49
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
My team (33) is using big LEDs to let the drivers know when something important just happened.
LEDs blue = ball possessed
LEDs green = lined up with a goal
LEDs red = latched onto tower and ready to hang
The last two were not functional at Kettering but will be at Troy
I think LEDs are the way to go because you can use them for multible functions. Although it does alert the other teams to our current scoring abillty ... Oh well well be getting hit anyway
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 14-03-2010, 20:27
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
We have one of these buzzers mounted in the center of our DS
http://www.radioshack.com/product/in...ductId=2062394
It turns on whenever we have a ball in our possession. As a driver, I can say that it is tremendously helpful and has definitely improved our performance. Panel indicators and LEDs aren't nearly as good because they require the driver to look at something other than the robot, or at least interpret slightly more visual data. I think that its quite a stretch to suggest that an intermittent buzzer of reasonable volume is going to bother your team mates in the middle of a supercharged match with music blaring and people cheering all around them.
Edit: I'm going to go ahead and recommend that specific buzzer from radioshack. Even though ours is just something someone happened to have, it looks just like that. It draws 15ma on 3.3 Volts, so you'll have to use one of the high current digital outputs. Hook the negative wire from the buzzer to the digital out so that a logic low turns it on-- the outputs can sink more current than they can source.
Unread 14-03-2010, 21:15
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Sorry if I wasn't clear
The big LEDs are on the robot and very visible.
Unread 14-03-2010, 21:30
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
BJC, they are automotive cold-cathodes. They are also very large, 12" long tubes, compared to LED's. We are powering them via Spikes on a dedicated 12v 20amp breaker, so no 3.3v DIO's here.
Kettering Motorsports
Unread 15-03-2010, 01:19
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Inspectors cannot allow air horns, sirens and other audio devices on the robot with sufficient sound level to create a distraction or hindrance that can affect the outcome of a match per: <R02.B>. Right now, there's no inspection item for similar devices on the operator's console. Do you wonder why there are so many rules??
Some students find it funny when, during inspection, I ask them if their robot has any lasers, flammable, flame sources, or toxic gasses. Frequently, I hear some "out-of-the-box" concepts involving flamethrowers, etc. All in good fun, of course.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
My case against <G14> bduddy General Forum 58 07-01-2009 15:20
Against all odds... ForgottenSalad General Forum 14 31-03-2007 17:43
Unsportsmanlike conduct. 3 against 1 angryyoungnpoor General Forum 16 14-03-2004 08:42
Rule G11 and Springs Rule mtaman02 Technical Discussion 3 23-01-2004 17:43
Can we use sirens on the robot? intx13 Rules/Strategy 14 18-01-2004 19:17
