Go to Post "I'd like the teeter-totter..." - Billfred [more]
Unread 14-03-2010, 18:28
Fennig247's Avatar
Fennig247 Fennig247 is offline
AKA: Fennig
FRC #0247 (Da' Bears)
Team Role: Scout
Fennig247 is a glorious beacon of lightFennig247 is a glorious beacon of lightFennig247 is a glorious beacon of lightFennig247 is a glorious beacon of lightFennig247 is a glorious beacon of lightFennig247 is a glorious beacon of light
Send a message via AIM to Fennig247 Send a message via Yahoo to Fennig247
Re: The 469 auto
So just to undermine this for a quick second, but what would it take to just play defense on the other 2 robots? if they dont score at all? and you stop the few couple balls 469 shot in during autonomous when they slide down the bump, would that not keep everything in contact to win a match?
Unread 14-03-2010, 18:39
Chris Hibner Chris Hibner is online now
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: The 469 auto
I'm not 100% sure what you mean. If it's what I think you're saying, you can't defend both of the other robots since you're only allowed one defender in the opponent's offensive zone.
Unread 14-03-2010, 18:44
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: The 469 auto
Can someone clarify 469's strategy for those of us unfamiliar with their robot this year?
Unread 14-03-2010, 18:45
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Re: The 469 auto
I think what he means is to block one goal with your defensive robot and situate your midfield bot on top of the bump in such a way that they block the balls that roll off of 469's ramp.
While this strategy would be effective in shutting down the scoring loop, you would be playing 1v2 elsewhere on the field and 469 could decide to start moving around, which could result in 4-6 points from them and/or draw your defense away from the tower long enough to allow them to restart the scoring loop.
Unread 14-03-2010, 18:49
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: The 469 auto
For those who don't know 469 is this years game breaking robot.
Their stratagy is to sit under the bump and deflect balls directly from the ball return back into one of the goals. Theu can deflect into either and at Cass tech over the weekend they won a match 26-1.
We are currently figuring out how to beat them
Any ideas?
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 14-03-2010, 18:50
JGurnow's Avatar
JGurnow JGurnow is offline
FRC #0217 (The Thunder Chickens)
JGurnow is on a distinguished road
Re: The 469 auto
Originally Posted by Chris is me View Post
In which case, you could have one defender in the zone and a second resting on the bump to stop transfers on one side.
Another robot can't physically get in the way on the bump. Their mechanism has maybe 3-4 inches of space below it and the top of the bump. You can't get into that position without causing physical damage to 469 which is against the spirit of FIRST.
I don't think you quite get that when 469 is in position the rest of the alliance is in the homezone. Only one needs to defend a robot. The other robot is there for clean up.
469 could traverse the bump without the tower on it. I am unsure, as are they, about whether they could go over without flipping now.
Unread 14-03-2010, 19:03
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Re: The 469 auto
On the contrary I am very aware of this.
The only way to prevent a blowout is to lodge yourself at a 45 degree angle in the tunnel in auto.
Then even with crazy traction 469 will have a hard time pushing someone out of that position who also has traction because their isn't a good way to push them from.
That being said it doesn't really matter anyway because for the next two regionals their in their pretty much going to be with you (217) so Troy and the Michigan Champs are going to see the exact same thing Cass tech did.
You can call me a pessimist but I call them as I see them.
Unread 14-03-2010, 19:05
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Re: The 469 auto
Ok, some team in their six hour window just needs to build a robot that is strong, fast and agile. Now all you have to do is stop their first attempt and play heads up defence, pestering them but keeping yourself b/t them and the tower.
Unread 14-03-2010, 19:06
Re: The 469 auto
You could get there in autonomous by backing up a little bit, OR just do nothing in autonomous and back onto the bump as 469 unfolds their arms.
What if 469 (or another team with similar capability) could also deflect balls straight ahead (in addition to directing them toward the goals). That would probably defeat that strategy as well.
Unread 14-03-2010, 19:08
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Re: The 469 auto
But remember, they could push an elephant.
Oh well, at least teams will have a sort of fighting chance if someone lodges themselves under the tower before them.
Unread 14-03-2010, 19:22
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: The 469 auto
What if you had a small robot that could fit sideways in the tunnel?
Could someone post a picture of 469?
And I thought you were not allowed to cross the white line in auto?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 14-03-2010, 19:26
Re: The 469 auto
You're not allowed to be ENTIRELY on the other side of the white line, but you're allowed to straddle it.
If it isn't obvious, I'm hooked on this thread. I need to shut off the laptop and do something useful.
Unread 14-03-2010, 19:27
Chris is me's Avatar
AKA: Pinecone
Re: The 469 auto
You can't completely cross it, but you can partially cross it.
Unread 14-03-2010, 19:28
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Re: The 469 auto
Correct considering 469 did it all Cass Tech without getting called I should hope its legal.
Unread 14-03-2010, 20:17
roboraven15's Avatar
roboraven15 roboraven15 is offline
FRC #1188 (Oaktown Crewz)
roboraven15 is an unknown quantity at this point
Send a message via AIM to roboraven15
Re: The 469 auto
someone needs to copy their robot in a tiny 6 hour window and do the same on the other side lol good luck....
Using auto cad for the autodesk inventor competition [527]phil Inventor 7 18-01-2006 10:41
Creater of the DeLorean auto dies Jay H 237 Chit-Chat 4 23-03-2005 12:54
Ruling for what defines being at the auto-loader Andrew Schuetze Rules/Strategy 4 15-01-2005 22:41
Team 469 and the Gyro archiver 2001 0 24-06-2002 02:57
Team 469 is the coolest!!! yystickers Off-Season Events 0 19-11-2001 14:51
