Go to Post Spell Check is your friend! - dez250 [more]
Unread 14-11-2001, 19:37
Andrew Wyatt Andrew Wyatt is offline
#0524 (Alpha Omega Robotics)
Andrew Wyatt is an unknown quantity at this point
Send a message via AIM to Andrew Wyatt
Quick disconnect Control board
in preparation for next year, our team is coming up with a control board that quickly disconnects from our robot for repairs. our one major snag in this endeavor is a suitable connector.
does anyone have suggestions for a connector that will take the amps and is still a quick disconnect?
There are only two tools you really need: duct tape and Wd40. if it moves and it shouldn't, use the tape. if it should move and doesn't, use the wd40.
Unread 14-11-2001, 20:19
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
We have our control board on a piece of lexan that is connected to our base with hinges so we can pull it out for easy access and fold it in during the matches. Here is the kind of connector we used for the wires:
One wire is the female, the other wire is the male and it makes it really easy to disconnect and reconnect wires.
There aren't really any good pictures of our control board, but this is probably the best. The lexan is the part with the light sticking out of it and on the other side is all the electronics. All of the wires coming off of the board are grouped into small clumps on each side of our battery so they can be easily disconnected.
Unread 15-11-2001, 20:36
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
Use the force...
Quick disconnect, eh? Amps, eh? You can use the connectors from something such as a defunct printer; that should provide you with enough channels for anything, and if you want you can use multiple pins per channel to use enough wire to feel... um, safe. There's a team that uses this exact setup, though I can't remember which one. But this works!
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
Shelf and board dimensions still don't add up kmcclary Off-Season Events 12 20-10-2001 09:12
