Go to Post Being involved with FIRST is a privilege, not a right. - Katie Reynolds [more]
Unread 04-03-2010, 00:36
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Show us your practice robot. Here's ours
Here's a video of one of our drivers practicing driving our practice robot thru the tunnel. The practice robot is exactly the same size as our competition robot including bumperes. It does not have a kicker nor a CRIO control system. We use a 2.4 ghz Futaba spread spectrum radio control airplane system. It's a lot easier to set up and provides excellent control. The only thing we can't do is autonomous. http://rambotics.com/video6.html
Unread 04-03-2010, 01:43
dtengineering's Avatar
AKA: Jason Brett
Re: Show us your practice robot. Here's ours
Great idea to have a practice robot, especially with omni drive. It takes a lot of driver practice to make up for the brute pushing power of a 6 or 8wd system with the elegance of the omni.
I'm curious, though, why you chose not to put your cRio on it... or even keep your kicking mechanism behind, too, as part of the witholding allowance.
With a bit of forethought you can put all your electronics into one box that transports easily from a practice robot to the "real thing" and can do a lot of software work while you await competitions.
But hey... at least you're practicing! That's gotta help!
Jason
Edit: here's ours http://www.chiefdelphi.com/media/photos/34973
Unread 04-03-2010, 10:08
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Hi Jason,We kept the CRIO back as part of the with holding allowance. The reason we don't use it on the practice robot is the Futaba 2.4 ghz system has far more capabilities (exponential, on screen programing, etc) and is far easier to use. To get it up and operating all we have to do is turn on the transmitter and recv. Look for signal lock and then turn on the robot. We don't have to mess with the classmate or worry about a modem. The drivers have been running for over 30 minutes a pop without turning the system off. The holonomic drive does take practice and that practice is begining to show. I can't imagine showing up at competition with a holonomic drive the drivers have only had a few hours to drive.
Unread 04-03-2010, 20:13
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Just getting picky here but the FCC says it is illegal to use an airplane radio to control a ground vehicle and vice versa.
Bruce
Unread 04-03-2010, 20:24
hyperdude's Avatar
hyperdude hyperdude is offline
Techie.
AKA: Mike W.
FRC #2503 (Warrior Robotics)
hyperdude has a spectacular aura abouthyperdude has a spectacular aura abouthyperdude has a spectacular aura about
I think, based on the line "a 2.4 ghz Futaba spread spectrum radio control airplane system", that it's an RC-airplane control system, not an airplane radio.
Unless I'm somehow mistaken.
Unread 04-03-2010, 22:35
CrashTestPilot's Avatar
CrashTestPilot CrashTestPilot is offline
AKA: Rafal Myslak
FRC #2338 (Gear It Forward)
CrashTestPilot is an unknown quantity at this point
Yes, believe it or not, FCC covers the remote controlled airplane and helicopter models as well.
Not sure if it is still true for 2.4 ghz radios, but it was not legal to use radios on 72.5 (frequency designated for model airplanes and helis) to control any other vehicles. What that means is that one should not use such radio for R/C car, boat, hovercraft, etc. I think this was mainly for safety reason - these model airplanes are only supposed to be flown at designated fields and you wouldn't want to get shot down by interference caused by someone using radio on the same frequency to drive an R/C car in their back yard.
Bruce - what do you fly?
Unread 04-03-2010, 22:42
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
2.4 ghz is a ground frequency. All is good. (At least according to the RioBotz Combot tutorial.)
I'd never thought of using a hobby radio system to practice...
Unread 05-03-2010, 10:29
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I've been flying 30+ years and yes it was illegal to run a ground vehicle with an aircraft radio. With the new 2.4 GHz radios I'm not sure it is.
I'm currently flying a Goldberg Cub. It's 15+ years old. It has an O.S. Surpass .70.
I also have a Royal Spitfire with a new O.S. Surpass .90 and a new Futaba radio for sale. $500.00 never been flown.
Sorry for the shameless for sale plug
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 12-03-2010, 03:02
MFS766's Avatar
MFS766 MFS766 is offline
FRC #0766
MFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of light
2.4GHz to 2.485GHz can be used for both aircraft and surface usage.
Here is a link explaining which frequencies can be used for RC:
http://www.modelaircraft.org/events/frequencies.aspx
Sadly, we dismantled our practice bot for parts. But we still have functional '09, '08, '07 and '06 robots for practice. And we have a "black box" software control being developed for our kicker operator to practice. If we can get it to work, it should simulate the firing sequence of our kicker so our operator can get in the habit of know where the buttons are without looking. We will have to see if will work, at least we get an ergonomic test for the OI.
Unread 12-03-2010, 22:30
quadrinim quadrinim is offline
FRC #0296 (Northern Knights)
quadrinim is an unknown quantity at this point
BTW.... my anti virus blocked a trojan as I went onto your link, you may want to look into that.
Unread 13-03-2010, 10:50
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
2.4Ghz is exempt from the old FCC regulations.
andi would show our practice robot....if it wasnt in pieces
Unread 13-03-2010, 21:37
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Ball control practice.
Since ball control is such a key part of this years game, we're spending a lot of time practicing it with our practice bot. As you can see from this video http://rambotics.com/video7.html the practice has evolved into a game of keep away between the driver and a human player.
Unread 13-03-2010, 21:43
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Our "practice" robot is the frame, motors, and shifters of our 08 robot, with our kicker mounted to it currently. The drive is similar, since both our 08 and 10 robots are 6wd, although 08 is much faster, and turns quite a bit better. We don't really have an official practice bot though... Our 08 bot is just our testbed for programming during build season. The only reason it's now a practice bot is because we removed our kicker in DC last week and brought the assembly back with us to work out the bugs.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
Unread 15-03-2010, 07:22
AKA: Warthog
Here's our practice bot. It's the one on the right (Delta Fire)
http://www.chiefdelphi.com/media/photos/35176
Your Fav. T.V show! fancy013 Chit-Chat 30 24-01-2005 14:08
Show us your Plays! Sachiel7 Regional Competitions 17 09-03-2003 23:25
Show me your ramp!! evulish Chit-Chat 0 15-01-2003 15:54
engineers here's your time to shine archiver 2001 1 24-06-2002 00:28
downtime, not ours or venturesonline fault Brandon Martus Announcements 0 26-12-2001 16:05
