Go to Post People should listen to this Andy Baker character, he seems like a smart guy... - Karthik [more]
Unread 15-03-2010, 01:40
Frank Neuperger Frank Neuperger is offline
FRC #0842
Frank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to behold
Team 39 building 469 stopper solution (Available in Las Vegas)
Guaranteed 2 on 2 solution available for purchase at regionals (just kidding but read post 10 or all for some additional constructive countermeasures).
CIM driven ducted fan package with on board jaguar and pig tailed wiring for quick attachment to your robot. Free Labview VI or programming support to control it. Unit weighs 5.8lbs including CIM motor.
Fan has optimized exit duct with wide vertical aperture to ensure maximum dwell time of the falling ball in the airstream.
And yes, the balls end up in opposition home zone but not in their goal.
If you feel that your robot needs the edge to defeat these endless loop robots, this is the solution for you. With easy attachment, and sure deflection this is your ticket for helping those alliances in need of serious defense.
If you are interested, please respond.
(Available for prompt purchase and return at the Las Vegas regional for teams interested. There will be a $5.00 restocking fee.)
Patent Pending.
Last edited by Frank Neuperger : 15-03-2010 at 15:06. Reason: added note that this offer is not genuine as some readers missed the emoticon.
Unread 15-03-2010, 01:52
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Re: Team 39 building 469 stopper solution (Available in Las Vegas)
That sounds like a great idea Frank, it would be very easy to implement, and we could literally put it on any team trying to duplicated 469 that is going to Vegas. Even a not so good robot could attach this thing and be a great contender. Great job. I can't wait to see these things in the shop. Seams fairly simple and effective.
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 15-03-2010, 02:11
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Sounds like a solid plan, but i believe FIRST does have rules against teams selling items like this to other teams... (Not Positive, but pretty sure)
There was some drama about this when team 221 llc came out, but they are not directly affiliated with the team i think, they are like a mini andymark.
However, you can make a whitepaper and show others how to do it, or just stick it on your alliance partner before elims reinspection?
Or you could have just not been serious this whole time and I cant pick up sarcasm? Im good at missing things like that
Unread 15-03-2010, 03:05
FRC #0842
We figured this would be a productive outlet for some of the serious fan technology developed during lunacy.
I recall a CIM solution on our field in Atlanta with 7 lbs of thrust. For an orbit ball deflector, we had tested but eventually decided not to use a FP motor swinging an 8 inch propeller. Perhaps even a FP coupled correctly with its 185 watts output might even be enough for this disruptor. The lower speed CIM is a better candidate for the bigger fans as it's speed is 3x slower than FP and requires no gearbox.
The key to deflecting the soccer balls enough to disrupt accurate scoring will be high air velocity and some vertical aperture to the airstream. This could be an attractive strategy for those robots lacking ball handling mechanisms. Built right, it is a sure ticket to finals against an endless loop bot.
Not sure this really needs a white-paper as the concept is fairly simple. Put fan low and run lightweight duct up to the 51 inch mark. Lots of RC aircraft calculator programs on the web for matching motors to props.
Last edited by Frank Neuperger : 15-03-2010 at 04:50. Reason: typo and some detail added.
Unread 15-03-2010, 09:30
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
469 needs to trademark their name and number as quickly as possible. They could cash in on all the hype surrounding them.
Unread 15-03-2010, 09:34
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
I'm even sick of hearing about us...
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 15-03-2010, 09:38
sashboy226 sashboy226 is offline
FRC #0226 (Hammerheads)
Team Role: Student
sashboy226 will become famous soon enough
Or teams could just prevent them from locking onto the tower...I already know of several teams making anti-guerilla autons
"This is not Ninja-botics"
Unread 15-03-2010, 09:39
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Then quit now before it's too late!
GitHub
Unread 15-03-2010, 10:30
ExTexan's Avatar
ExTexan ExTexan is offline
Parent and Volunteer
AKA: Richard Singletary
FRC #0548
ExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant future
Mason, Mason, Mason....you move to the Left Coast and immediately start thinking like them!
Don't forget your MI roots and don't fear....The contraption was invented in MI and the countermeasures will be deployed in MI. So hang tight and watch what we do!
64 teams at States.....only 2 will be their partners....that leaves 61 of the best MI teams that will want to have a defense. (PM me the cost of your fan )
What we think, or what we know, or what we believe is, in the end, of little consequence. The only consequence is what we do.
2010 REFEREE: Kettering, Ann Arbor, Wayne State, Troy, MI Championship, Atlanta-Newton field, IGVC TARDEC, MARC and upcoming KETTERING Kickoff.
Unread 15-03-2010, 14:41
FRC #0842
Good to see everyone on both right and left coasts picking up the gauntlet on this.
Our post was in reaction to the doom and gloom outlook over this at the time I made the original post. Our team was even pondering doing a variant within the 65lb hold-back but that is largely scuttled.
The fan and several other schemes can deal with this. The real trick is how to come up with a scheme that will not just simply convert a total annihilation situation into a sure defeat with two 469 partners on on 1 opposition but with less points margin for 469ers. The trick is to level this to a 2 on 2 or a 1 on 1 and have a fighting chance.
The fan scheme is deployed when 469 has engaged to the tower possibly irreversibly. Not clear that the 469 can un-deploy the mechanism in order to abandon the tower if they find themselves ineffective. That leaves a 2 on 2 scenario unless one or both of the 469 partners tries to dislodge the low geared high traction fan bot.
The fan bot is preferably a "wide drive" and parked wide side against the tower. Bid side against 469 presents less of a moment arm opportunity for 469 partners to push a distant fan bot corner corner and dislodge the fan bot. The wide drive scheme presents transverse wheel friction to minimize probability of being moved when pushed on its narrow end. Lastly, the ideal fan bot would drop high friction roughtop pads on the floor to make them really hard to move in any direction. Lastly the ideal fan bot would be able to swivel the fan turret slightly to tweak aim as the dislogers are working on pushing the fan bot around.
In qualifications however , it is probable that a lone fan bot will never meet 469 and thus never be tested against them.
Another countermeasures strategy specific to 469 is that with the correct timing of slamming into their back end, you can put significant movement on the top part of their tower exactly when the ball is seemingly stationary or near stationary for a moment. This would catapult the ball far enough towards the end zone so that the ball guides will be ineffective. Remember that they can have only 3 inches of ball penetration in their mechanism so even an inch of movement forward largely disenegages the guiding effect and 3 inches of movement has that ball in free fall without guides.
It was frustrating to watch one after the other of the one sided matches and not see 469's opposition exploit this simple shaker scheme.
Drivers that are to face 469 could practice by watching the 469 videos while driving their bot in the pits against a dummy target. Figure out far far back you need to be with full throttle to make the hit at the exact correct time. Pick a station for the rolling ball on gantry to pass to give it full throttle.
An alternate shaker scheme just has you against the 469 bumper and punching the throttle to get the entire 469 gantry into resonance. Like trying to rock a van. Just repeatedly punch the throttle with some good eye hand coordination timing. Let it bounce you back and punch again. In 10 to 15 sec, you should master this just like you do when you rock van. .
A loop bot that grabs the tower higher up to stabilize their ramp will not be as susceptible to the shaker schemes.
Note that on many but not all balls, the ball appears stationary for a moment at the moment of catch on the 469 mechanism. Any rules on this? Videos were not closeups so not sure on this
469 came up with a novel and legislatively risky scheme and developed it. Hats of to them. I am glad that the concept (not the execution of it) did not get legislated out by a late rule change. 469 surely had many problems to solve to make this work right. I think the game may end up one sided in some venues but the FIRST community will be better for it. It demonstrates the real world possibility that your technical endeavor or business can come up against great odds and you need to rise to the challenge of countering it. Legislation and lawyers are one way in the real world to deal with this (Car racing, sailing, in business..... ) but in FIRST I hope this drives more of a technical innovation route. You can invent around seemingly insurmountable obstacles.
Hmm perhaps intelligence to GDC of the existence of loop bots drove the increase of hold-back to 65 lbs. I had wondered why they did that at the late stage and perhaps this was the reason.... so that teams could make countermeasures changes or do their own loop mechanism. Anyone think of a better reason for that late rule change. With 65 lbs, you can almost build a full robot.
Discussion/debate is invited.
Last edited by Frank Neuperger : 16-03-2010 at 01:54. Reason: polish and typos and more typo's
Unread 15-03-2010, 14:59
The Lucas's Avatar
CaMOElot, it is a silly place
Originally Posted by Frank Neuperger View Post
Hmm perhaps intelligence to GDC of he existence of loop bots drove the increase of hold-back to 65 lbs. I had wondered why they did that at the late stage and perhaps this was the reason.... so that teams could make countermeasures changes or do their own loop mechanism. Anyone think of a better reason for that late rule change. With 65 lbs, you can almost build a full robot.
Team Update #11 increased the Withholding Allowance to 65 lbs in response to the record snowstorms in the Mid-Atlantic Region. Many teams lost a week plus of build time near ship day as schools closed and states of emergency were declared.
Robot Inspector
Unread 15-03-2010, 15:02
FRC #0842
Thanks for the clarification. I was not aware.
I suppose we can be thankful for the storms in triggering the additional hold-back mechanism.
This will surely allow more effective countermeasures against loop bots.
Unread 15-03-2010, 15:54
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
They can, and have, left the tunnel after deploying their mechanism.
All this apocalyptic talk of 469 and their ilk running rampant and destroying the competition is a little premature, don't you think? We've only played two weeks and seen one of these bots dominate. Perhaps we should let the game evolve a bit, first?
Unread 15-03-2010, 16:24
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
The 469 strategy is pretty effective, but it is beatable. I posted here: http://www.chiefdelphi.com/forums/sh...1&postcount=42 basically saying that they can't do anything without soccer balls. The videos I saw were showing some pretty ineffective defending robots that could not clear the ball out of the zone.
There are some physical limitations to just how fast the trident can be used to feed the balls in. Also, a good coach will have the defense driver over there letting them know when balls are coming in. It does require a strong robot with a kicker.
The shaker strategy would have been an easy one to try at Cass Tech. It would be a good way to test out the robustness of their mechanism.
- T
Unread 15-03-2010, 16:26
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
A loopy robot that grabs the tower higher is asking to be made into a pendulum. the worst loop bots will have multiple attachment points. Then you would have to match the resonance of the tower. <and risk field damage?>
Any tests on how tolerant the tower is to rosonant movement with a robot locked onto it?
Las Vegas Regional team social. JM987 Regional Competitions 0 28-03-2009 00:26
pic: Team 597 at the Las Vegas Regional Joe Ross Extra Discussion 0 03-04-2007 22:12
pic: Team 359 at the Las Vegas Regional 2007 Joe Ross Extra Discussion 6 02-04-2007 02:15
pic: Team 230 Body painting at Las Vegas Regional brinsy625 Extra Discussion 5 05-01-2007 13:41
