Go to Post There's something about building a robot that just makes people enthusiastic about life. - BBnum3 [more]
Unread 15-03-2010, 16:28
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Autonomous runs during Teleop
Originally Posted by Greg McKaskle View Post
Next using either Find or the hierarchy window, determine if you are explicitly calling the Autonomous Independent VI.
Greg McKaskle
As you predicted, this is the issue. You can see in the attached code posted above that the call from Robot Main that is typically to Autonomous Iterative has been replaced with a call to Autonomous Independent.
For any others having this problem this is a good first thing to check. To use Autonomous Independent, the only thing you have to do is make sure that the enum at the top of Begin.VI is set to Independent and then place your code inside the existing Autonomous Independent VI accessed from the Project Explorer.
Directions During Autonomous helenajoy NI LabVIEW 2 22-02-2010 19:30
HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIEW rokenboker NI LabVIEW 9 05-02-2010 17:10
Scoring During Autonomous Mode KrakatoaCoo Rules/Strategy 7 15-01-2010 16:16
Labview Autonomous AND Teleop Two-Face Programming 1 14-02-2009 18:33
No Tracking During Autonomous jdejoannis Programming 4 10-02-2007 14:46
