Go to Post In the professional world, spelling mistakes, grammatical shortcuts, leet-speek, and misused verbiage are not interpreted as signs of cute, efficient communications. They are indicators of illiteracy, inefficiency, unprofessional behavior, and sloppy work habits. - dlavery [more]
View Poll Results: How does your robot posess the ball?
Roller (Ball magnet) 123 65.78%
Vacuum 35 18.72%
Armature 0 0%
We do not intend to posess the ball 11 5.88%
We did not ship a posession device, and will decide before competition 18 9.63%
Voters: 187. You may not vote on this poll
Unread 23-02-2010, 20:05
ubermeister's Avatar
ubermeister ubermeister is offline
AKA: Eric VA
ubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the rough
Ball posession: Roller (ball magnet) or vacuum?
How are you possessing the ball? How well does it work? Any innovations from the original ball magnet or standard vacuum design?
We went with a vacuum and are very pleased with the results. It uses an ungeared FP motor and a 5" shop vac impeller. The end-effector is a thin plastic food container. We can drive at full speed while maintaining control of the ball.
It seems most teams went with roller designs. I'd be interested to see how these compare to vacuum designs.
Unread 23-02-2010, 20:12
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
Re: Ball posession: Roller (ball magnet) or vacuum?
We went with vacuum but actually added a ball magnet to grab moving balls and push them into the vacuum. It works very well for us. We can easily score three shots in 20-30 seconds if balls are nearby the bot.
Rob Self-
Cyberhawks Team 706
Hartland, WI
Our breakaway bot in action (13-3-1): Team 706 in action
Unread 23-02-2010, 20:19
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
we tried a ball magnet, but it didn't work, it just sucked the balls under the frame
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 23-02-2010, 20:34
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
AIR Strike is using a vaccum.
You can see it in this video:
Click
Unread 23-02-2010, 21:01
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
@ people using vacuums with those yellow funnels, where do you buy them? I looked around mcmaster but didnt see them...
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 23-02-2010, 21:03
ravichauhan ravichauhan is offline
FRC #0612 (Chantilly Robotics)
ravichauhan is an unknown quantity at this point
We are using a vacuum with a mcmaster carr plastic funnel. it worked but it will be more efficient to have a silicone one which we will attach before competition. we are using the fifth CIM for the vacuum because we are using the FP's somewhere else. Its speed is geared up 3:1. That will also be changed before competition to 5:1. What type of rpm are you other non-geared-FP guys getting
Unread 23-02-2010, 21:33
fuzzy1718 fuzzy1718 is offline
MTU class of '15
fuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant future
to those using the vacums, how are you stopping the suction when you kick? or are you?
What FIRST has taught me:
Money is not everything.
In order to change a culture one must change the hearts of the next generation.
The fish rots from the head down.
Why we do something is often more important than what we do.
Repeated success is often sown on the backs of a few, but reaped by many.
Unread 23-02-2010, 21:41
BradMello's Avatar
Broken Arrow
Team Role: Driver
Home depot is where we bought ours.
Just shutting off the vacuum prior to kicking equalizes the pressure fast enough that the ball will disconnect when kicked.
Unread 23-02-2010, 22:01
Vince's Avatar
Vince Vince is offline
FRC #0236 (Techno Ticks)
Rookie Year: 1994
Vince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond repute
I spy, with my little eye, two dog toys....
Unread 15-03-2010, 16:25
Austinmead's Avatar
Austinmead Austinmead is offline
Donut
no team (The Caiman Agents)
Austinmead is infamous around these partsAustinmead is infamous around these partsAustinmead is infamous around these partsAustinmead is infamous around these partsAustinmead is infamous around these parts
how'd you make the vacuum?
we know you replace the old vacuum motors with the FP motors but we cant get it to work
Unread 15-03-2010, 16:56
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
We're using a vacuum, but all our driver training was done without a ball possession device. Therefore, we may not end up using anything.
Unread 15-03-2010, 17:20
Bruceb's Avatar
Bruceb Bruceb is offline
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
As robself said earlier we use both a ball magnet and a sucker. The sucker is 2 shopvac impellers stacked back to back so that the output of the first feeds the input of the second. They are powered by 2 FP motors geared UP 2 to 1. Impeller rpm is about 19,000. Way much suck. We can move anywhere as fast as Robbie can drive and not loose the ball. We have the vac arangement at the back of the bot and the toilet plunger that sucks the ball at the front connected by 1.5 in. pvc with a wye in it. At the wye we have a small piston that holds a flat chunk of rubber over the hole. about 5 ms before we shoot we pull the piston and dump all the vacuum so we kick straight. This is VERY effective. We were the high scoring first zone bot at the Wisconsin regional and ended on the 2nd place alliance.
Bruce
Unread 15-03-2010, 17:24
Austinmead's Avatar
Donut
sweet... thats cool....ill look into designing that lol
Unread 15-03-2010, 19:29
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
We used a dump valve.
It is just a PVC pipe hooked up to the vacuum, with a pneumatic cylinder inside of it, to open the top. It gave us 5 different kicking modes, (Long w/dump,w/out, med with, without, short) with some great consistency. We would open the dump valve about 10-25ms before we kicked.
Unread 16-03-2010, 18:41
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
Do you happen to have an item # or a description of its real use? I just spent 2 hours in home depot looking, and the employees are no help.
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
Ball Magnet MrForbes General Forum 54 02-02-2010 17:04
842 ball roller falconmaster General Forum 3 02-02-2010 12:44
pic: Kit ball vs. New ball kborer22 Extra Discussion 15 09-02-2009 09:15
Knocking off a ball while possesing a ball Joe Ross Rules/Strategy 25 10-03-2008 18:49
WHere do you get Ball Casters/ BAll Transfers for FRC?!?!?!? leehyungjin4u General Forum 3 15-01-2008 23:27
