Go to Post FIRST builds bridges, and absolutely should not build walls. - Jacob Bendicksen [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 15-03-2010, 16:28
ISITME_YESITIS ISITME_YESITIS is offline
ISITME_YESITIS is an unknown quantity at this point
Human player errors
Hello i was wondering, if a human play drops the ball and it rolls away should they get it if it requires them to step outside of the line or should they allow it to roll away?
Unread 15-03-2010, 16:32
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Human player errors
How many penalties do you want?
1 for stepping outside the alliance zone (<G48> or <G49>)
or
1 every 2 seconds until the end of the match, after the DOGMA grace period expires (<G17>)
Your choice.
(since 2004)
Unread 15-03-2010, 16:35
Field reset is supposed to collect it and return it. How fast they are depends on a number of factors, like where they are, what's at the end of the field, etc.
Can you get it with the trident? If so, try that.
Will you have to leave the zone? If so, you will get a penalty.
If you leave the zone, will you be able to get back with the ball and get it up in the allotted time? If not, that's another penalty.
I'd say let it roll, let the resetters get it, and get a different ball up there pronto.
(BTW, this topic would probably be better in the Rules/Strategy subforum.)
Unread 15-03-2010, 18:01
sorry for the subforum it is CD put it because i forgot to select a folder.
So if they field reset crew can get it back to you quick enough for you to get it through the ball counter before DOGMA runs out than it is best to let them do that or will you recieve a penalty if they touch it?
Unread 15-03-2010, 18:03
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You will not be penalized for having the field reset crew return the ball to you (other than through DOGMA if you don't get it up in time).
Human Player WhiteShadow1474 General Forum 33 11-01-2009 12:07
Human Player Joe_Widen General Forum 62 24-04-2006 21:18
Human Player xxlshortys General Forum 17 20-04-2003 19:02
human player mattshuert OCCRA 2 05-11-2002 23:10
Human Player Steve Yasick Off-Season Events 1 09-10-2001 19:49
