Go to Post It's a twitter post. It's not a hint. - Libby K [more]
Unread 15-03-2010, 21:15
GLDomination GLDomination is offline
FRC #3145
GLDomination is an unknown quantity at this point
Problem with losing communication while on the field.
We are team 3145 and we won the rookie all-star award after losing in the quaterfinals at the Portland regional.
During our quaterfinal matches, we lost communication twice. I was wondering if there was any way that this could happen due to a physical problem. We were thinking that the camera may have been hit and that the cable may have popped out. Could this cause us to lose comm?(We lost comm for two matches and it happened around halfway through during each).
Any help would be greatly appreciated. We are trying to figure this out before we get to Atlanta, but it is hard to do without a robot. Thanks for any info you can give.
Unread 15-03-2010, 21:25
Re: Problem with losing communication while on the field.
Check your cables, especially between the cRIO and the gaming adapter. That's the most likely culprit. It probably wouldn't be the camera cable (why would not being able to see where the target is shut down communications?).
Unread 15-03-2010, 21:37
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Your camera coming unplugged COULD cause you lose communication in a way. I cannot speak for LabView, but if you are using Java and your camera code isn't set up correctly, an attempt to read the data from a disconnected camera could cause an exception that might crash the cRio.
I don't need a signature.
Unread 15-03-2010, 21:48
whackedwatchdog whackedwatchdog is offline
FRC #3224 (LHS)
whackedwatchdog is a jewel in the roughwhackedwatchdog is a jewel in the roughwhackedwatchdog is a jewel in the rough
If you're using the flat (Ribbon?) cable that came in the KOP, that might be your problem. When we were at Peachtree, and during practice, we had a couple of games where we lost communications for seemingly no reason. When we swapped the ribbon cable out to regular, bulky Ethernet cable, we had no problems. I don't know if it was absolute luck, or if there actually is a problem with those cables. Either way, it might be worth a shot!
rspurlin's Avatar
rspurlin rspurlin is offline
AKA: Ray Spurlin
no team (no team)
rspurlin has a spectacular aura aboutrspurlin has a spectacular aura about
First two places I would look would be the ethernet cable from the cRio to the gaming adapter and the power cable from the power distribution board to the gaming adapter. Loose connections on either of those would be a likely cause.
Do you regain communications? IF so, hoe long does it take? It could be the cRio rebooting after a power fail or other condition.
Mentor(2007-2013) - Team 1379 - Gear Devils - Norcross, GA
2010 Palmetto regional Semifinalists, Judges Award
2010 Peachtree Regional Quarterfinalists, GM Industrial Design Award
2009 Palmetto Regional Finalists
2008 Bayou Regional Quarterfinalists
2008 Peachtree Regional Semifinalists
2007 Peachtree Regional Quarterfinalists
Georgia FRC Planning Committee
Unread 15-03-2010, 21:50
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Look for intermittent shorts between the robot chassis and the cRIO or camera chassis. Use a multimeter to determine whether your chassis is electrically connected to any of the robot's wiring.
If the cRIO or camera momentarily touch a chassis that is connected to a voltage other than ground, the power supplies will probably reset.
Russ
Unread 15-03-2010, 22:00
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Invest in a HOT GLUE gun, and hot glue the Ethernet connectors into the radio and crio. Also hot glue the power connector in the radio. For that matter hot glue EVERYTHING, the PWM connectors into the victors, CAT5 cables into camera, etc. Hot glue all the way around each connector. Pot-it-in like the military people do it.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 15-03-2010, 22:31
Nuttle89 Nuttle89 is offline
AKA: Ben Nuttle
FRC #5332
Nuttle89 has a spectacular aura aboutNuttle89 has a spectacular aura about
We have had problems like this at both regionals we have attended so far. We tried tons of troubleshooting methods. From having our wiring looked at by an electrical engineer, to switching from 2CAN to CAN, to fully switching our code over from Jave to C++, we frequently would just lose communication mid-match. We even considered replacing our C-Rio at the regional..
As it turns out, we grabbed a spare radio from the parts desk, had it programmed, and we ran fine for the rest of the day. The issue is, there isn't a way to detect a faulty radio assuming it is getting power, not that I'm aware of.
It was extremely frustrating because we knew it wasn't our code or our hardware. We were assuming it was some error with the FMS. We never fixed the problem at the DC regional, and were scrambling to find the problem with the condensed schedule at Pittsburgh.
Unread 15-03-2010, 22:37
gordonsolo13's Avatar
gordonsolo13 gordonsolo13 is offline
FRC #0996 (Mecha-Knights)
Team Role: Electrical
gordonsolo13 is an unknown quantity at this point
It could have also been a problem with your classmate. If you allow it to go into hibernate after turning it on, it will have problems with connecting. We had problems on the first three matches at our regionals because of such a problem (along with our the fact that our during our first match our mechanics forgot to reconnect the speed controllers.)
Unread 15-03-2010, 22:41
Controls Engineer
AKA: chakorules
Oh, this is a GOOD point. This happened to us once and also when you close the lid on the classmate too. I know...ask my drive team :-) I closed the lid on them during drive practice one day, to ween them away from the camera feedback. I said "You just lost the live feedback from the camera during the match, so keep on driving..." Right when I closed the lid, the whole robot died...guess you had to be there. It was a funny moment.... Moral of the story, don't close your Classmate lid in the middle of a match, instead put a piece of paper over the screen to cover up the video feed...
Favorite CD quote:
Unread 15-03-2010, 22:46
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
Check the game adapter power cable. We had problems with communications on the field too. Come to find out the the power cable hole was too big for the pin and it would move and reset the game adapter. So find a cable that is closer to the pin size.
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Unread 15-03-2010, 23:44
Do you redo the hot glue each time you need to tether the robot?
At Phoenix, I saw several bad Ethernet cables, several bad bridges, and several bad electrical connections. We also had one team whose joysticks weren't recognized after restarting the classmate.
Unread 16-03-2010, 00:11
AKA: Dan
I know this isn't really part of thread, but why is it bad to have video feedback? We worked hard to get ours working well, now I'm wondering if there is a consequence we haven't thought of. Are the drivers staring at it too much?
Unread 16-03-2010, 00:28
Please don't do this. You will regret it as soon as you need to power up your robot in the pit.
Unread 16-03-2010, 09:19
It's easier to just minimize or close the Dashboard window.
Losing Communication Chief Pride FRC Control System 15 29-07-2009 17:46
problem while programming 2 bottuns in windriver mahmosh C/C++ 3 12-02-2009 12:25
Wireless problem - losing communication jalburty FRC Control System 9 09-01-2009 07:35
Chat with other ChiefDelphi visitors while browsing the site blue_crew Chit-Chat 5 02-01-2006 12:57
Robocode: Learning JAVA the fun way. While fighting with robots. Denalin Fusion Chit-Chat 2 26-09-2005 23:22
