Go to Post Robot: Gyro, please reset yourself and verify proper operation. Gyro: ... WHY IS THE EVERYTHING SPINNING SO FAST? HELP! ... Robot: Are you working yet? How about now? - EricVanWyk [more]
Unread 15-03-2010, 16:17
Rafael2215 Rafael2215 is offline
FRC #2215
Rafael2215 is an unknown quantity at this point
hard reset for classmate
Hi,
Apparently our classmate has a damaged WPI library. What should we do? Will getting it back to manufacturer settings (using the USB flash memory supplied with the classmate) do the trick?
If so, can anyone brief me on how we should do it?
Thanks,
Team 2215
Unread 15-03-2010, 17:32
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: hard reset for classmate
just reinstall WPILib: http://first.wpi.edu/Images/CMS/Firs...te20100217.exe
Watchdog.Kill();
Unread 15-03-2010, 17:38
FRC #2215
So I just copy this exe to anywhere on the classmate and run it?
Should I backup anything before I do it?
Unread 15-03-2010, 20:07
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
a rule of thumb seems to be to back up anything that you don't want to loose, though i doubt that the wpi lib install would cause issues, still it can't hurt to have backups
Unread 15-03-2010, 20:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Note that the link posted above is for C++, if you are using Labview it will not do anything for your WPILib problems.
Unread 15-03-2010, 21:31
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
You can always restore from the image provided in the KoP on a flashdrive.
Unread 15-03-2010, 22:44
MishraArtificer's Avatar
MishraArtificer MishraArtificer is offline
Winner, Chief Delphi Insanity Award
AKA: Jeremy Marr
FRC #0240 (T.E.M.P.E.S.T.)
MishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of light
Probably the single biggest thing I don't like about the Classmate: no optical drive. You lose that flash drive, you're pretty much hosed. And if they'd added a DVD-ROM drive, they'd have had enough room for a larger keyboard and touchpad, too.
Also...
[off topic] How much are you allowed to do to the Classmate, hardware/software-wise? Any chance of adding memory? (I'm assuming the processor is hardwired directly to the board, what with it being that ****ed small...)[/off topic]
Madness?
THIS IS F.I.R.S.T!
Unread 15-03-2010, 22:48
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
See R60
Unread 04-11-2010, 07:13
fimhk fimhk is offline
fimhk is an unknown quantity at this point
Sorry but I might need help to restore the classmate pc second generation but I have no KOP USB restore one. Is there a way for me to get it or is it possible to download the files somewhere?
Thanks so much,
Tom
Unread 06-11-2010, 07:11
AKA: Jeremy Marr
Thanks so much,
Tom
I would start by checking the date of the last post before necroing a 9-month old thread.
That said, do you have access to an external DVD drive and a Windows XP (Home, I think...) Edition disk?
Madness?
THIS IS F.I.R.S.T!
Unread 06-11-2010, 08:55
Out of curiousity, I checked the FAQ on forum usage but couldn't find any etiquette relating to this issue. Is it generally considered appropriate and acceptable to post an on-topic new query to a dormant (but open) thread (as fimhk did), or is it preferred to start a brand new thread covering basically the same topic (as MishraArtificer seems to be suggesting).
Perhaps the CD forum-master, or some charter members, could give some authoritative advice on this.
Unread 06-11-2010, 11:20
AKA: Jeremy Marr
It depends on the forum and the age of the thread. Different forums have different rules regarding it. Most of the forums that I visit frown on replying to a thread over (usually) three months old, especially if it hasn't been visited or posted in since then. One even locks threads over six months old, unless the original poster wants to update the thread with new information (in which case, they have to send a request to the forum admins).
WITH THAT BEING SAID, I suppose it could be okay on this one, as it may be saving valuable database space for something more complex...like calculations on the likelihood of a water game...
Back on topic, fimhk! How's that Classmate of yours doing?
Madness?
THIS IS F.I.R.S.T!
Missing AC Adaptor for Classmate PC DynamiteRoboKid Kit & Additional Hardware 2 10-02-2010 19:43
Camera won't initialize when reset from RC - reset from OI and Power-up works, krunal Programming 7 15-01-2007 00:13
Reset Button for Vex RC's irishninja FIRST Tech Challenge 5 18-06-2006 15:56
Partitioning my hard drive for redhat mechanicalbrain Chit-Chat 2 18-09-2005 07:25
A hard decision for a college student Elyse Holguin Chit-Chat 7 15-09-2004 19:37
