Go to Post The trick is to train the rest of the team to blame electrical instead. - Al3+ [more]
Unread 16-03-2010, 07:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Power your Classmate PC with this cable
After reading about the extensive problems with teams' Classmate PC's dying, and anticipating a greater problem as the season goes on, I have developed a simple solution that I am happy to make available to all teams who wish to purchase it. Pictured below, this cable plugs into a standard FRC robot battery, and provides a fused cigarrette-lighter socket to plug a power inverter into. This adapter cable can be used with an inverter to re-charge the Classmate PC when an outlet is not available (such as in the pre-match lineup). It is also quite useful for scouting teams in the stands, and outdoor demonstrations.
Purchasing will be handled through RobotWires.com. Orders placed today, and tomorrow should arrive in time for teams competing at Week 4 events.
Unread 16-03-2010, 07:58
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Power your Classmate PC with this cable
Whats the black gizmo in the middle?
Unread 16-03-2010, 07:59
The piece in the middle is a weather-tight fuse holder with a 15-Amp automotive blade type fuse inside.
Unread 16-03-2010, 09:13
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
We made one of these and it works very well, we also use it for out pump to keep our tires inflated.
Unread 16-03-2010, 09:21
foote stepped in
AKA: E. Foote
FRC #0868
I had a similar solution made a couple years ago for the bus ride to Atlanta - my laptop only had a 2 hour battery life, and we had a bunch of old batteries.
Very simple to make.
I suggested my team use it for the upcoming regionals, I think they were planning on it anyway.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 16-03-2010, 13:59
ErichKeane ErichKeane is offline
FRC #3210
ErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really nice
Send a message via AIM to ErichKeane
Hmm... wouldn't it be more efficient (not having to deal with the AC->DC->AC conversion) to keep it DC?
One end has the same battery connector, the other has the barrel connector for plugging in directly to the laptop. In the middle, all you need is a simple 12v->20v converter, which is a little bit of circuitry: http://english.cxem.net/car/car4.php
2004: Team 219- Programmer/Designer/Builder
2009: Team 2374- Mentor
2010: Team 3210- Mentor
Unread 16-03-2010, 14:38
It looks like you aren't the only one getting into this business: http://www.andymark.biz/am-0626.html
Unread 16-03-2010, 14:41
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
For something like this, "quick and easy" usually trumps efficiency.
Unread 16-03-2010, 19:13
Bob Steele's Avatar
AKA: Bob Steele
it is interesting that you did this...
We actually built one of these on the fly during the elimination matches at Oregon. It saved our bacon on the field...
By the way... scuttlebut is that some regionals and possibly the Championships will have AC available at the Driver's stations to plug in the classmates..
Just a rumor
It would be a good step...
R
Unread 16-03-2010, 19:36
MrForbes's Avatar
AKA: Jim
At Arizona they announced at the end of Friday that there would be power at the driver stations Saturday. Saturday morning they announced there would be no power at the driver stations.
Unread 16-03-2010, 21:21
AKA: Dr. Brooks
no team (WRRF)
More efficient, yes.
More compact, yes.
Safer, yes as there is nothing over 20 volts.
You can buy a 12vdc-20vdc converter from www.powerstream.com,
make sure that you get the 5.5mm-2.5mm plug and exceed 2 amps,
and then change the cig plug for a battery connector.
Or, you might drop into Radio Shack and buy the
iGo anywhere NetBook charger, which has both a
110 volt and a 12 feed, RS part number 273-377
Lots of teenagers playing with inverters makes worry about safety!
Eugene
Unread 17-03-2010, 00:13
These both look like good solutions, but a bit expensive ($40+). I figured many people already have inverters they use in their car, and the only missing link for these folks is something to safely connect it to the battery with.
Unread 17-03-2010, 07:51
Sandrag,
Gold star for including the fuse. Those of you making your own, consider this a necessary feature. The battery is capable of very high currents and needs protecting.
Myself and others are lobbying hard to provide power at the driver's station for the Classmates. After two weeks of regionals with teams failing to compete due to batteries dead or dying during finals matches should have been enough but there is no word yet.
Unread 17-03-2010, 08:17
My inverter has an integral 40a fuse, so in some cases an additional fuse may be unnecessary.
But it must have one somewhere.
Unread 22-03-2010, 14:00
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
The only thing i would caution Mark - if you're hooking the inverter up through something like this (which provides a 12V car power socket to hook up to the input to the inverter), having an in-line fuse as shown at the beginning of the thread is a good idea. I doubt anyone's worried too much about the safety risk the inverter presents (as every inverter I've seen includes a fuse), but if the inverter isn't present and the cable is plugged in, the power socket on the end is wide open to being shorted. In cars, these sockets are protected by their own inline fuses, and the same should happen here.
In our case, we had taken an inverter, snipped the power cable, and hooked it up straight to the Anderson connector. In this situation, the on-board fuse for the inverter provides sufficient protection against shorts, as there are no removable intermediate connectors prior to that fuse.
Power cable & Missing parts BetsySpike Kit & Additional Hardware 1 16-01-2010 15:37
Setting up your new Classmate for Java technology techplex Java 2 10-01-2010 23:46
axis camera power cable falling out.. dani190 Electrical 7 19-02-2009 13:55
2007 Controller Power cable? reflion Electrical 7 16-01-2009 07:33
Camera power cable MustangRobotics General Forum 11 12-01-2006 22:39
