Go to Post Weren't you ever told Canada is backwards from the US? - Alex Cormier [more]
Unread 16-03-2010, 08:34
steppmjk steppmjk is offline
AKA: Mike Stepp
FRC #3242 (Wildcats)
steppmjk is an unknown quantity at this point
Pneumatic speed
We need to increase the speed and force of our kicker.we have two 3/4" x5 double action cylinders on it now.Would increasing the diameter of the cylinders help?Also we use surgical tubing to assist , would it be better to use single action cylinders or should we stay with the double action that we have?
Unread 16-03-2010, 08:39
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Pneumatic speed
Do you think you can provide us with a picture?
A bigger bore cylinder will be able to pull back more force in springs, but if you don't have a separate release mechanism you'll find that the cylinder is restricted by friction in the cylinders linear slide and how fast air can exit.
Unread 16-03-2010, 08:40
karpiron karpiron is offline
FTA
karpiron has a spectacular aura aboutkarpiron has a spectacular aura about
Re: Pneumatic speed
Are you using a dedicated solenoid for each accuator
Unread 16-03-2010, 10:09
Re: Pneumatic speed
Increasing the cylinder diameter increases the force, but decreases the speed.
Adding more cylinders can maintain the same speed, and increase the force.
Some speed increase can be obtained by opening up the exhaust port of the cylinder to the atmosphere (remove all fittings and use the bare cylinder port) and retracting it with a spring or elastic, like surgical tubing.
The problem with having a cylinder directly in the loop is that it will act as a shock absorber by slowing your kick to the speed that air can be pushed out of the open end of the cylinder or pumped into the charged end.
One way around this problem is to latch the cylinder partially extended and precharge it to get around the 1/4" feed tube restriction. Then release the latch.
Unread 16-03-2010, 13:28
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Pneumatic speed
Are you using two solenoid valves, one on each cylinder? Do so if not. In the past we have even used two solenoid valves on each cylinder (some inspectors crinkled their nose at this.) The flowrate through the valve is your primary bottleneck. Increase the amount of tension on your elastics until the return force of the cylinders can barely hold it back, this will maximize their contribution to your speed and force.
Unread 16-03-2010, 16:41
AKA: Mike Stepp
Re: Pneumatic speed
We're using one valve for both cylinders.what kind of latch can I use to load the system?
Unread 16-03-2010, 16:49
Re: Pneumatic speed
A regular gate latch is the most common I've seen used this year with a separate tiny cylinder to unlatch it.
If you do the precharge trick don't pull the cylinder all the way back when it latches. Leave a couple of inches of cylinder as precharge volume.
You can also do a variation, such as
  1. using a cylinder to pull back a heavily elastic powered kicker
  2. latching it back
  3. returning the cylinder to it's forward position
  4. opening the latch to kick
  5. repeat.
Unread 16-03-2010, 16:57
AKA: Mike Stepp
Re: Pneumatic speed
Thanks for your help I'll giv eit a try
Unread 16-03-2010, 17:41
dtengineering's Avatar
AKA: Jason Brett
Re: Pneumatic speed
Put your valves as close to your cylinders as you can so you keep your tubing runs short (you have to vent/pressurize the tubing as well as the cylinder, remember).
Try putting a clippard tank right next to the valves on the low pressure side of the system. That means you've got lots of 60psi air right next to your valves, and close to your cylinders. You can even use the brass fittings to connect your vavles directly to the cylinder.
Jason
Unread 16-03-2010, 18:52
AKA: Mike Stepp
Re: Pneumatic speed
Do you think two smaller cylinder is better than one large one?
Unread 16-03-2010, 20:40
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Pneumatic speed
This may or may not be true. There can (and usually are) many 'bottlenecks' in a pneumatic system such as using 'Tee' fittings instead of 'Y' fittings. Do not assume that your bottleneck is the valves, instead test,test,test.
Each cylinder has a volume that is to be filled. The valve has a flow rate (Cv) for which only a certain amount of air can pass (actually the flow rate is a curve based on pressure difference across the orifice). You'll need to find the appropriate flowrate to volume ratio for your needs.
Standard gate latch from home Depot.
  2. latching it back
  5. repeat.
These tips are probably the best.
Jason
Jasons tips are for if you do not precharge your system. If you do precharge your system then you want the volume between the valve and the cylinder (giving more air in the precharge) and the largest orifice in between (1/8" to 1/8" nipple fitting).
Good luck.
___________________
- Tennyson, Ulysses
Unread 16-03-2010, 21:02
sgreco's Avatar
AKA: Steven Greco
FRC #2079
Re: Pneumatic speed
I'm curoius why this makes a difference? It's a closed system and (aside from the two pressure regulators), the pressure is constant thoughout the system regardless of the size. So when you release the solenoid, all you're doing is blocking one passage way and opening another, then the air gets redistributed. I'm sure there is a reason for your point, I'm just curoius what it is because before now I would have assumed that based on the nature of the system length/size shouldn't make a difference. Does it have to do with leaks? I'm aware there is air loss in the system, but wouldn't that be caused by the number of connection and not the length?
Unread 16-03-2010, 21:16
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: Pneumatic speed
The air has to flow through the hose. The higher pressure air moves through the hose in a wave that replaces the lower pressure air. In a shorter hose that wave will reach your cylinder faster. Trust me, it makes a big difference.
Unread 19-03-2010, 16:09
AKA: Mike Stepp
Re: Pneumatic speed
Anyone have any data on surgical tubing, like best size or optimal power to stretch?
Dangers of High Speed Pneumatic Gun neilpatel92 Pneumatics 25 29-01-2010 15:32
Pneumatic Actuator Speed? WorkingFromHome Pneumatics 3 20-01-2010 00:09
pic: Four-Speed Ball-Lock Single-Pneumatic Transmission Design Bootsie Extra Discussion 14 25-08-2009 14:55
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
