Go to Post While one student may not be of much value to the team, do we ever stop to think about how much value the team may be to that student? - Madison [more]
Unread 15-03-2010, 08:08
Re: Rule against Sirens?
As David has pointed out there is no rule against a noise source in the DS, however, do you really want to risk distracting your alliance partners?
Unread 16-03-2010, 11:29
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
Originally Posted by The Lucas View Post
We use a rumble pak that vibrates when we grab a ball. That doesnt make much noise and gets the drivers attention (they never look at LEDs). We used the rumble pack last year to indicate when our turret sees the target. I have heard other teams use them as well (not sure who). Rumble paks are easy to reverse engineer to work with a digital out (heck if convicts can figure out how to make tattoo guns with them, then it shouldn't be too difficult for a young engineer).
Team 78 uses something very similar, we've used modified logitech dualshock 2 controllers for the last two years. The logitech dualshock two controller is the same model as the standard controller provded with the FTC kit of parts....only with a rumble feature. Last year we simply rewired the motors that controlled the vibrate inside the controller directly to the digital output of the DS and controlled it accordingly, but this year it required the cypress board to achieve the same effect.
By using the can bus on our jaguars we can monitor the current our vaccum is drawing and trigger the vibration motors when the current drops (when we have a ball in our possession). As a driver its particularly helpful when going for the balls that are against the bump nearest to me, which I can barely see.
Unread 16-03-2010, 12:00
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Driver should be looking at the robot, so we put a light on the robot, activated by a vacuum switch on our ball sucker.
Vacuum switch is fairly inexpensive, and commonly used on high efficiency home furnaces.
Unread 16-03-2010, 12:19
With a 102db buzzer, I should think that your biggest problem would be your alliance partners beating you with their control stations.
My case against <G14> bduddy General Forum 58 07-01-2009 15:20
Against all odds... ForgottenSalad General Forum 14 31-03-2007 17:43
Unsportsmanlike conduct. 3 against 1 angryyoungnpoor General Forum 16 14-03-2004 08:42
Rule G11 and Springs Rule mtaman02 Technical Discussion 3 23-01-2004 17:43
Can we use sirens on the robot? intx13 Rules/Strategy 14 18-01-2004 19:17
