Go to Post just a gentle reminder not to limit yourself to just one viewpoint - every problem can and should be examined from different angles - dlavery [more]
Unread 16-03-2010, 12:49
rokenboker rokenboker is offline
FRC #1236
rokenboker is an unknown quantity at this point
Exclamation NI LABVIEW Compressors
hi, can anyone give me some code on how to run the compressor on the 2010 control system. i have the code that i will upload in a little bit. we REALLY need this for our robot to fucntion.
Thanks.
Unread 16-03-2010, 13:00
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: NI LABVIEW Compressors
Please search before you post in the future. This is a common topic with many threads addressing your question. A search for "Labview Compressor" brought up many of them.
http://www.chiefdelphi.com/forums/sh...w+compresso r
Unread 17-03-2010, 13:21
FRC #1236
Exclamation Re: NI LABVIEW Compressors
hi, i am uploading the screenshots for my code...in the word doc. are the pic.s
can anyone tell me if this code is correct for these needs:
1 compressor, 1 single-acting solenoid (activates when button is pressed), tank drive.
if i need to change anything, please let me know.
Thanks
Unread 17-03-2010, 13:43
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Thanks
From what I can tell your code looks like it should work for that setup.
Note that the solenoid will only remain "activated" as long as the button is held, it will go back the other way when you release the button.
Unread 17-03-2010, 14:47
FRC #1236
thanks. i'll be working on the autonomous code now...i'll post the code when it's done...
HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIEW rokenboker NI LabVIEW 9 05-02-2010 17:10
Pneumatics Air Compressors and Such JohnFogarty NI LabVIEW 3 05-12-2009 21:59
Air Compressors bhsrobotics1671 Regional Competitions 22 09-03-2008 21:26
Compressors vs. Accumulators Pavan Dave Pneumatics 6 31-01-2007 09:46
Two Compressors Jay H 237 Pneumatics 16 16-02-2004 20:55
