Re: Pneumatic speed
Are you using two solenoid valves, one on each cylinder? Do so if not. In the past we have even used two solenoid valves on each cylinder (some inspectors crinkled their nose at this.) The flowrate through the valve is your primary bottleneck. Increase the amount of tension on your elastics until the return force of the cylinders can barely hold it back, this will maximize their contribution to your speed and force.
| Dangers of High Speed Pneumatic Gun | neilpatel92 | Pneumatics | 25 | 29-01-2010 15:32 |
| Pneumatic Actuator Speed? | WorkingFromHome | Pneumatics | 3 | 20-01-2010 00:09 |
| pic: Four-Speed Ball-Lock Single-Pneumatic Transmission Design | Bootsie | Extra Discussion | 14 | 25-08-2009 14:55 |
| Drive Control, Wheel Speed Calibration, and Rapid Speed Changes | 7-11number1 | Programming | 3 | 23-01-2008 20:36 |
| speed controller max speed | Team 668 | Programming | 15 | 13-02-2005 14:05 |
