Go to Post "The robot is horribly overweight. We need to delete some code" - Dumper FTW 435 [more]
  #31   Spotlight this post!
Unread 13-01-2010, 16:45
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Lifting mecanisms
http://media.atc.wpi.edu/News/Events...errage2004.wmv
In 2004, 190 had a telescoping arm/winch system.
The cable controlling the telescoping action was a light weight line, that only had the weight of the telescoping arm applied to it. The weight of the entire robot was lifted by a second steel cable. These were both powered/spooled by the same motor.
  #32   Spotlight this post!
Unread 13-01-2010, 17:21
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by ttldomination View Post
During the finale, robots can come out into and around the bumper zone, and with an unlimited number of servos, the top tier teams will easily be able design a mechanism to prevent bumper snagging.
Talking with my physics, he has assured me that using a CIM to lift the robot would definitely suffice, and it'd be fast too.
And for those who are considering a worm gear, a worm gear will rip itself apart before it goes against the motor, but they are extremely slow. And I mean EXTREMELY slow. IMO, it'd take at least 10-15 seconds to get up beyond the 20".
Good Luck,
- ttl
*ahem* A 30:1 reduction with a 2" pulley will lift a bot in under 4 seconds. In fact, a 2" pulley needs at least a 14:1 reduction just to get to half stall torque. So you need a reduction in the worm gear range unless you're using extremely small pulleys and beating up your motor.
  #33   Spotlight this post!
Unread 13-01-2010, 17:50
JosephBurns35's Avatar
JosephBurns35 JosephBurns35 is offline
AKA: Joseph Burns
FRC #2487 (Mechanical Animals)
JosephBurns35 is an unknown quantity at this point
Send a message via AIM to JosephBurns35
picking up other robots would be cool but how would you center the weight of your own robot so that you wouldent swing on the bar. when you try to pick them up
we are also looking at using a spooled wire and winching ourselves up but the problem is getting the arm that deploys the wire to fold up small enough to fit through the tunnel
  #34   Spotlight this post!
Unread 16-03-2010, 15:26
nskerven nskerven is offline
FRC #2062 (C.O.R.E.)
Team Role: CAD
nskerven is infamous around these partsnskerven is infamous around these partsnskerven is infamous around these partsnskerven is infamous around these parts
What would be the safest amount of weight a single CIM Motor could lift 20"? We can easily lift ourselves in just a few seconds but I don't know how hard it will be for the motor to lift us and a second robot at the same time.
  #35   Spotlight this post!
Unread 16-03-2010, 15:35
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
3 sec x 200 watts is 600 Nm. A full weight robot is about 667 N so,
You could lift 1 robot 0.9 meters or 2 robots 0.45 (17.7")
Of course you need frictionless bearings and what not...
CIMs are somewhere between 200 and 300 Watts depending on battery voltage and ...
  #36   Spotlight this post!
Unread 16-03-2010, 16:22
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
A fully loaded robot (120 + battery + bumpers) is closer to 150 lbs, which would put you closer to 750N
But that's a rather small difference.
What's important to remember is that although the PEAK power of a CIM is over 300W (I think), that requires it to be run at ~40% stall torque. If you run at at ~80% stall torque, you'd probably not even get 100W of electrical energy out of it (but you would get tons of thermal =D). So, although on paper the CIM has plenty of power to lift in 3 seconds, you need to effectively use that power.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
  #37   Spotlight this post!
Unread 16-03-2010, 16:44
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
1lb=4.448N ... 150*4.448=667.2N...
Yep small difference indeed.
Agreed on the importance of effectiveness. Not only proper gearing, but don't forget real-world losses. 1-5% per gearstage and/or chain drive. Properly designed and supported systems can get quite efficient. Gearboxes made with hand drills and drill-presses often are not.
The 200W is quoted off of MK's motor database that uses 10.5 volts from a power-supply. Yes your battery may be as high is 15 volts (300W), but by the end of the match, with a high load, I wouldn't count on it.
  #38   Spotlight this post!
Unread 16-03-2010, 17:46
pfreivald's Avatar
AKA: Patrick Freivald
We had no problem lifting ourselves in about four seconds with a single CIM on a 4:1 Banebots plus a four-start screw for reduction. (We engineered it for a 3:1 gearbox, then put on the 4:1 just in case).
Wouldn't a more effective strategy be to lift yourself, have something mechanical lock into place, and then let the other robot use their own lifting mechanism?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #39   Spotlight this post!
Unread 16-03-2010, 18:08
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
2foot long 2in bore pneumatic cylinder
60 psi * 1in radius * 3.14 ~ 188 lbs of lifting.
problem solved. if u already have a pneumatics system in place on your robot or can afford the weight. i can see a lift in the sub second range (with enough accumulators on the robot)
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
  #40   Spotlight this post!
Unread 16-03-2010, 18:11
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
It's not nearly that simple...
The air usage of such a cylinder is a huge issue. Also, retraction force is less than that theoretical value, and if your robot is dragging up the tower you may need to provide more force than you expect. Also with that short of a throw you need to make sure to keep the robot pretty level to get it all above 21"
This is not to say it can't be done (I really, really hope it can), just that there may be more to it than first glance would suggest.
Heavy Lifting Spen.M.P. Chit-Chat 9 23-01-2009 06:29
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
Lifting robots rjbarra Technical Discussion 8 09-01-2007 01:23
robot lifting doomsdaytank Rules/Strategy 2 14-01-2003 16:41
Lifting goals patrickrd Rules/Strategy 6 17-01-2002 17:58
