Go to Post Thanks for the heads up on the elevator game. - Andrew_L [more]
Unread 16-03-2010, 21:02
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Pneumatic speed
Originally Posted by dtengineering View Post
Put your valves as close to your cylinders as you can so you keep your tubing runs short (you have to vent/pressurize the tubing as well as the cylinder, remember).
I'm curoius why this makes a difference? It's a closed system and (aside from the two pressure regulators), the pressure is constant thoughout the system regardless of the size. So when you release the solenoid, all you're doing is blocking one passage way and opening another, then the air gets redistributed. I'm sure there is a reason for your point, I'm just curoius what it is because before now I would have assumed that based on the nature of the system length/size shouldn't make a difference. Does it have to do with leaks? I'm aware there is air loss in the system, but wouldn't that be caused by the number of connection and not the length?
Dangers of High Speed Pneumatic Gun neilpatel92 Pneumatics 25 29-01-2010 15:32
Pneumatic Actuator Speed? WorkingFromHome Pneumatics 3 20-01-2010 00:09
pic: Four-Speed Ball-Lock Single-Pneumatic Transmission Design Bootsie Extra Discussion 14 25-08-2009 14:55
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
