Go to Post Ahh! I see that you discovered the "CMD_FLING_RECEIVER_RADIO_ACROSS_ROOM" command in the robot scripting language! Nicely done! - dlavery [more]
Unread 16-03-2010, 10:37
xnaut's Avatar
xnaut xnaut is offline
Team 79 KRUNCH
AKA: Patrick Thompson
FRC #0079 (TEAM KRUNCH)
xnaut is a jewel in the roughxnaut is a jewel in the roughxnaut is a jewel in the rough
Send a message via AIM to xnaut
Was Wondering how hard it would be to use a standard USB webcam with labview
ive got no particular robotics team reason to need this, it is basically for my own use, my issue is that all the vision VIs supplied require IP addresses, something USB ports do not have...
Shirley you cant be serious...
Of course i am... and don't call me Shirley
_____________________________________________
TEAM KRUNCH 79
CLEARWATER FL
Unread 16-03-2010, 11:07
Re: Was Wondering how hard it would be to use a standard USB webcam with labview
Yes, USB ports lack an IP address. This is not particularly troublesome, considering that the cRIO lacks USB ports in the first place.
Unread 16-03-2010, 11:29
As Alan pointed out, it is not feasible to do so with the FRC cRIO. However, USB webcams are very well supported for other targets, such as desktop computers.
Unread 16-03-2010, 11:37
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
What he is asking is if there is a VI to get image from USB cam on his computer. I haven't found one, but maybe said VI exists.
Kettering Motorsports
Unread 16-03-2010, 11:42
xnaut's Avatar
Team 79 KRUNCH
Yes, im not trying to put this on a C-rio, just my computer
TEAM KRUNCH 79
CLEARWATER FL
Unread 16-03-2010, 12:04
LabVIEW has an IMAQ USB library, but we didn't get it as part of the special FRC software load.
Unread 16-03-2010, 12:20
Corey Oostveen's Avatar
Corey Oostveen Corey Oostveen is offline
FRC #2771 (Code Red Robotics)
Corey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant future
This might be something that could help.
http://zone.ni.com/devzone/cda/epd/p/id/5030
Known Issues:
- NI-IMAQ for USB Cameras only supports a single acquisition from one device at a time.
- Launching and closing camera sessions repeatedly will cause a minor memory leak.
- Exiting LabVIEW without closing the session properly will cause a system failure.
- Using an external image display window on a dual-processor machine or hyper-threaded machine may cause the computer to freeze when moving or clicking the external display window
Best of luck to you!
Unread 16-03-2010, 12:31
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
I know you were asking about using a USB camera with Labview, but have you considered using Java? It has a number of tools built into the API that can handle video and image processing, even from a USB camera. Plus it has the extra advantage of being FREE. Plus a Google search revealed a number of sample programs to accomplish the task.
DISCLAIMER: I do almost all my programming in Java, so feel very comfortable with it. I have little experience with Labview and just get confused by all the blocks. That will be my project this Summer (to learn Labview)!
I don't need a signature.
Unread 16-03-2010, 21:50
This reminds me of the 1986 Titanium Guitar project. These sorts of projects are an excellent way of learning a new language and general programming and debugging skills. If you find that you need drivers or other tools, it doesn't hurt to ask.
Greg McKaskle
Unread 05-04-2010, 22:22
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
NI-IMAQ USB is exactly what you want. Follow the link a few posts up-- the add-on is available at no cost.
Non-standard USB controllers with the OI CapnKernel FRC Control System 1 31-01-2010 02:08
Need Help: FRC Labview with local USB-cam (or laptop Webcam) Ziaholic NI LabVIEW 6 21-09-2009 16:43
Using Standard Labview with cRIO writchie FRC Control System 2 23-01-2009 13:44
How many USB chicklets can you use? TheyShallRule Control System 1 09-01-2008 16:43
Any way to use standard radios with Mini RC? evan_wilson Control System 3 10-03-2007 21:48
