Go to Post I can't wait for the next season to start and my anticipation has already started. But in a way, if you think about it, the season's already started. - nehalita [more]
Unread 17-03-2010, 01:20
dtengineering's Avatar
AKA: Jason Brett
Re: IR Beam Breaking Circuit
We used three Sharp IR sensors (http://www.robotshop.ca/sharp-gp2y0a...sensor-1.html).
We desoldered the three JST input terminals and soldered a servo cable in their place. Then we plug each sensor directly in to an analog input port, and point the rangefinders forwards, looking out just beneath our "ball magnet" roller.
Now we not only know when there is a ball in our possession... we also know when we're getting close to a ball (or a wall... it ain't perfect) and can start up our ball magnet automatically. One less thing for the driver to do... or one less power drain as opposed to leaving it on all the time.
I guess we could even use it to check to see if two balls are in our ball magnet... although we haven't written that code yet.
Right now we're using our practice bot to try and see if we can come up with a dashboard display to help the driver find balls in the far end of the field, or use the rangefinders to help with auto mode.
Jason
Broken Beam Sensor? lollypop2020 Electrical 12 27-02-2010 19:01
pic: Beam Bending Example kramarczyk Technical Discussion 22 19-05-2008 08:08
NEED: carbon fiber/kevlar/composite I-beam Gabe15 General Forum 2 10-01-2008 08:44
IR Beam Troubles Goldeye Programming 2 21-01-2006 17:15
Gearbox breaking? ReggieB Motors 10 23-02-2004 06:55
