Go to Post And who knows, maybe one day you'll prove the impossible possible! - MissInformation [more]
Unread 17-03-2010, 01:15
bobrenjc93 bobrenjc93 is offline
FRC #3061 (The Federation)
bobrenjc93 is an unknown quantity at this point
Send a message via AIM to bobrenjc93
How to attach an impeller to a CIM motor
Any ideas?
I'm thinking some sort of adhesive. I do however have doubts on how it will hold...
Unread 17-03-2010, 01:27
dtengineering's Avatar
AKA: Jason Brett
Re: How to attach an impeller to a CIM motor
I've seen elsewhere that teams have used a gear or pulley system to increase the RPM of the CIM. Don't know what type of impeller they were using, or whether that is an option for you.
If you have access to a lathe, you should probably be able to turn a little aluminum or steel collar for the CIM shaft. You could make it a press fit... but looking at what you've got there... you could probably just put a cotter pin through the whole thing (impeller, collar, CIM shaft) to hold it together.
If you don't have access to a lathe...hmmm... a bit tougher decision.
Jason
Unread 17-03-2010, 01:33
You bring up a good point, so a CIM motor maxes out at a little under 5000 RPM, do you think a simple impeller + CIM will be able to create the suction needed to possess a soccer ball?
Also, just curious, do you know how people attached their rollers to their CIM's?
Unread 17-03-2010, 01:42
AKA: Jason Brett
There are already some threads on this, like this one http://www.chiefdelphi.com/forums/sh...t=cim+impeller
I don't know if you've tried searching, but you can usually find things more quickly that way than by posting and waiting for a reply. Sometimes you'll have to try using different search terms, and sorting through a bunch of irrelevant stuff, but it is almost always worth it.
As for attaching a CIM to a roller... presumably a ball magnet type roller... I'm not sure how many teams are using CIM's to do that. We are using the FP motor with a Banebots P60 transmission, and have machined the roller to directly accept the output shaft of the tranny, so it both supports one end of the roller AND turns the whole thing at the same time.
No reason you couldn't do that with a CIM, I suppose... but it might be a bit fast.
I think you'll also find that we had the option of ordering some nice drive belts as part of the KoP this year.
Good luck figuring out some solutions.... and with your searching!
Jason
Unread 17-03-2010, 01:47
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
We have threaded the shaft of a cim motor before. You need a 8mm die (or 5/16), and a good way of holding the motor shaft to keep it from turning when doing so. Its tricky but we got it to work on our 09 bot's fan.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 17-03-2010, 07:26
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
It is very unlikely that you will get enough suction (delta P) by direct driving an impeller with a CIM. We geared our impeller up 3:1 (the impeller turns 3 times as fast as the CIM motor) to get the necessary rpm. Also, you might look for a different impeller than the one pictured. That is a mixed flow (both axial and radial flow) impeller like what you might see in a turbocharger. This design is a compromise between flow and pressure. What you want is a pure radial flow impeller like you would find in a shop vac. Volume flow rate is not very important, you want to maximize pressure change. A large diameter, narrow cross section impeller will give you that. If you can find a 2-stage impeller, so much the better.
Former Mentor Team 1771
Former mentor Team 4509
Unread 17-03-2010, 08:53
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We used a shop vac. Removed everything but the impeller, housing, and motor. Then we removed the armature from the motor shaft with a press and mounted a toothed belt pulley on the motor shaft, another on the CIM, with a 3:1 increase in speed.
Tried gears first, but it was very loud.
How to attach wire to motors? jgraber Motors 11 22-01-2009 16:58
How close can you mount the IFI Controller to a CIM motor Capt. Quirk Control System 8 20-02-2008 19:37
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
How do i attach pictures? Captain Thunder CD Forum Support 1 22-06-2007 16:56
How to remove pulley from CIM motor de_ Motors 14 01-02-2006 20:49
