Go to Post Wow, I am beginning to feel like a member of the fabled "vast right-wing conspiracy" :) - Jim Zondag [more]
Unread 17-03-2010, 10:05
KyleWishnok's Avatar
KyleWishnok KyleWishnok is offline
FRC #2544 (HCRC)
Team Role: Driver
KyleWishnok will become famous soon enough
Robot Communication
Hello everyone,
Our team recently attended the Pittsburgh regional. Ever since we have returned home our robot will not communicate with our router. I remember them telling us something that we had to do but i cant remember what it was. If anyone can help us please post.
Thanks
Unread 17-03-2010, 10:08
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Re: Robot Communication
Generally, they encrypt your radio so that their FMS can communicate with the robot. Your best bet would be to restore to factory default (insert a paperclip end into the reset area of the radio for 5 - 10 seconds) then reset the radio the way you need it.
If anyone knows a better way, i'd like to know, because I'm not even a big fan of this idea.
"Don't worry, programming can fix it"
Unread 17-03-2010, 10:09
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
You need to reconfigure your radio to remove the encryption. You can either do it from scratch (hold reset, then reconfigure static IP to not use WPA), or log into it and set it to use no encryption.
I don't know if you have the WGA or the WRT, but directions for configuring both are here: http://usfirst.org/uploadedFiles/Com...ed-Rev-0.7.pdf (page 45ish, its in the ToC too).
To reconfigure without reset, just set your computer's IP to Static (and in my case) 10.04.69.(pick your favorite # 0<n<255) (the middle 2 #s are your team #, so 10.25.44 for the OP) and go to security (I think) and disable encryption.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
team 3080 problem no robot communication executionR Technical Discussion 1 20-02-2010 23:32
HELP! Robot Communication RedHeadRobotics Technical Discussion 4 12-02-2010 00:49
Robot to robot communication John Gutmann Programming 19 07-12-2005 08:18
communication between the robot controller and the interface Shlomi32 General Forum 4 05-12-2005 16:53
mini made robot communication John Gutmann Electrical 1 19-07-2005 23:16
