Go to Post i will not post here...i will not post here....well...okay, yes I will - David66 [more]
Unread 17-03-2010, 10:15
ThisAintJeff's Avatar
ThisAintJeff ThisAintJeff is offline
FRC #1591 (Greece Gladiators)
ThisAintJeff is an unknown quantity at this point
Send a message via AIM to ThisAintJeff
Bridge Problems
So you know how they reformatted the bridge at the regional competitions? well we just got it back with our robot, and im trying to set it back up to the way it was. only problem is, its not working. im following the "getting started gide", but its not working with those instruction. any help?
Unread 17-03-2010, 10:21
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Re: Bridge Problems
First off, http://www.chiefdelphi.com/forums/sh...threadid=84356
Second, which bridge are you using? The WGA (black box) or the other one (which looks... more slick? and is silver).
Either way, the easiest way to do it is probably to reset it (hold down the reset button w/ a paperclip or something for 5-10 seconds). Wait for it to finish (lights will stop blinking) which will take ~30 seconds. Then, log back into it (IP depends on model, both are posted in the guide http://usfirst.org/uploadedFiles/Com...ed-Rev-0.7.pdf
Just configure IP and Default Gateway to Static (not DHCP), and it should work again (remember IP is 10.15.91.1 for your team and Default Gateway is 10.15.91.4).
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 17-03-2010, 10:51
Racer26 Racer26 is offline
Re: Bridge Problems
I've always been able to reset it by logging into it at:
10.TE.AM.1
and logging in as admin (password: admin)
then setting the WPA settings back to no encryption.
Unread 17-03-2010, 11:13
Re: Bridge Problems
it is the black box. tried all of these methods. still no connection
Unread 17-03-2010, 11:36
Re: Bridge Problems
heres what ive done: ive set the DS classmate to auto find IP (and ive tried 10.15.91.5). Ive reset the bridge 3 times (after trying), ive tried multiple spots in the router, ive tried other ethernet cords. ive tried pinging the default IP adresses, with no connection.
Unread 17-03-2010, 11:46
Re: Bridge Problems
If you've reset the bridge to defaults, then you need to change your computer to a compatible IP address. 10.x.x.x won't work anymore. The instructions in section 2.10.1 of the control system manual won't completely work either, because they assume the router is a factory defaults and gives you a compatible IP address via DHCP. You would manually need to set your IP to 192.168.1.x to talk to the bridge if you did factory defaults.
Unread 17-03-2010, 11:53
Re: Bridge Problems
ive set the router to the factory default now. my DS should be at 192.168.1.10?
Unread 17-03-2010, 12:38
Re: Bridge Problems
You shouldn't be messing with your Driver Station. Leave its address alone (10.15.91.5, which the DS application sets automatically when given the 1591 team number).
wireless bridge problems tanguma26 Programming 8 31-01-2010 11:16
Wireless Bridge Problems furiousgeorge Control System 9 28-01-2010 13:28
bridge connection problems Bob Holmstrom Programming 9 21-03-2009 15:31
DS to Bridge connection problems CHSboy Control System 1 24-02-2009 14:07
Bridge problems? archiver 2001 8 24-06-2002 03:22
