Go to Post you should see my scout sheet its the bomb diggity - Mirza95vx [more]
Unread 17-03-2010, 11:55
Boommaster713's Avatar
Boommaster713 Boommaster713 is offline
FRC #0932 (Circuit Chargers)
Team Role: Driver
Boommaster713 is an unknown quantity at this point
Re: fine control of robot with mecanum wheels
Something to be aware of is that during testing my team found that in order to control the robot at low speeds the motors must be given 40% of maximum voltage (to overcome the robots moment of inertia) and then once the robot is moving the power can lower slightly.
Other issues that could impact fine control is the lag time between control system and robot.
My Team's robot uses a near identical setup, 8in andymark Mechanums wheels(with black mini wheels), andy mark toughboxes, chains connecting them with andymark wheel tensioners (Fiddly to the extreme to get right, but once right they havent failed through 13+ matches)
all done open loop with no feedback, with jaguars on PWMs, and joystick mapping for fine control
Robot control is a 3 axis joystick
jaguar speed control of mecanum wheels Ether Motors 7 05-02-2010 13:02
Spinning the Robot with Mecanum Wheels Teammax Technical Discussion 21 02-02-2010 18:14
Help with mecanum wheels CyDrive Programming 7 10-02-2008 16:16
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 14-01-2008 17:42
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 06-10-2005 09:38
