Go to Post But no matter how you place, the thing to watch for is the character change in the team members. The trophies are only important for a few hours. The character that is built will last a lifetime. - BrothersKeepers [more]
Unread 17-03-2010, 16:31
keericks's Avatar
keericks keericks is offline
AKA: Kent
FRC #1671 (Buchanan Bird Brains)
keericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of light
pic: 1671 Electronics Board (90%)
Unread 17-03-2010, 16:32
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Re: pic: 1671 Electronics Board (90%)
How do you feel the ribbon cable effects speeds of the Crio???
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 17-03-2010, 17:01
We used ribbon last year with no problems. Kent, I can't tell from the picture but I see wires leaving the jaguars and going between two c channels on either side of the robot. If they (the channels) are at the same level, a good hit to the side of the robot might pinch the wiring. I like the layout, everything centered in the robot and short wiring that an inspector can easily see.
Unread 17-03-2010, 17:19
keericks's Avatar
AKA: Kent
Rick as to your post above, we've noticed zero difference between ribbon and cable.
Al, to your point we already corrected that wire routing to go down through the board vs. around the outside edge just for that reason. This was a temporary mounting and hookup to get the bot ready for our open house event. Thanks for the feedback!
Unread 19-03-2010, 10:58
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Looks great.
Thanks Kent you have really helped our electronics team out this year.
We really appreciate it.
pic: Electronics Board Team2339 Extra Discussion 1 15-01-2009 19:31
pic: 1902 Electronics Board Sayrah Extra Discussion 3 09-02-2008 16:42
pic: Top of electronics board keenanmolner Extra Discussion 4 19-02-2007 00:57
pic: Side of electronics board keenanmolner Extra Discussion 1 18-02-2007 20:15
pic: 1023 Electronics Board KTorak Robot Showcase 1 13-02-2006 21:57
