Go to Post I GET that FIRST is about more than winning on the field. BUT... ...it is my experience that the great programs of the FIRST world almost always build on a foundation of competitive robots. Success on the field begets success in other realms. - Joe Johnson [more]
Unread 18-03-2010, 00:12
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Motor Speed with joysticks
One way to do this would be to pass the joystick values through a case structure before they go to the Robot Drive VI you are using (Arcade, Tank, etc.)
Wire the two buttons you want to have pressed into an AND and the result of the AND into the Case Selector Terminal (the little green question mark). Now if both buttons are pressed you will be in the True case and if either or both aren't pressed you will be in the False case.
Now we need to put the correct operations in each case. In the True case you want full forward on the sticks to be full power, this means that the joystick values should pass straight through the case structure unmodified.
In the false case you want to scale the value down to 25% of the maximum. To accomplish this divide each of the joystick axis values by 4 in the false case before passing them out.
Joysticks with circular motion Tom Line Electrical 28 04-03-2009 20:07
Motor speed sensing with the Jaguar motor controller? mminutto FRC Control System 5 13-01-2009 18:13
problem with motor speed bsbllpss Electrical 3 29-01-2008 10:07
RoboEmu v1.02 (now with real joysticks!) rbayer Programming 2 02-10-2002 15:24
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
