Go to Post With computers, every once in a while you see something that makes you think "I could have done this, why didn't I think of it? It would have made my life so much easier." Now is one of those times. - Nadav Zingerman [more]
Unread 18-03-2010, 01:05
Best Available Data
FRC #1778 (Chill Out!)
Re: pic: 2791's Brand New Arm
Originally Posted by Andrew Schreiber View Post
Just a personal off topic request, could someone who CAN explain this well (or at least point me in the direction of the relevant equations) elaborate on this. I am an ignorant CS major but I am REALLY curious.
Sorry for threadjacking Chris.
Wikipedia does a good job with the math under this heading: "Second moment of area for various cross sections"
I tried writing more in depth descriptions, but I can't get something down that uses the math.
In physical terms, think of it like holding 2791's arm with one end in a vice. If you were to press down on in, it would take a lot of effort to bend it. However, to bend it away/towards you would take significantly less, right? It seems from Chris's post that it was in this away/towards bend that the air failed. It turns out that adding just a little material in the plane that bending is occurring gives you much more strength.
TL;DR 2791 built an arm well prepared for tension/compression, but not strong enough for bending.
P.S. This all assumes I read Chris's original post correctly. By bowing, you meant that head on the arm used to look like || and now looks like ()... right?
pic: 2791's Shifting Winch Chris is me Extra Discussion 7 10-03-2010 07:46
Brand New Team TheKing General Forum 32 22-01-2008 09:02
pic: brand new custom built control center eshteyn Extra Discussion 35 14-01-2007 22:49
pic:THREE PICS OF NEW ARM!!!! LOOK!!!!!! sgsdragons Robot Showcase 0 13-02-2005 22:37
RAMBOTS, brand new webpage. archiver 2000 0 23-06-2002 23:06
