Go to Post Inertia is one cruel mother. - PayneTrain [more]
Unread 18-03-2010, 01:35
team_1026 team_1026 is offline
FRC #1026
team_1026 is an unknown quantity at this point
Question Retracting cylinder after kicking
Hey all! Is there a way that I can retract my cylinder after kicker the ball? I am working with a solenoid with 1 input and 2 outputs. I want it to bring the cylinder in because I don't want to get penalized for having something beyond my frame perimeter for more then 2 seconds. Thanks!
Unread 18-03-2010, 02:16
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: Retracting cylinder after kicking
once the solenoid is false the cylinder should retract provided it is wired up corectly
for example button three kicks release it and the piston retracts
Expect the best, Prepare for the worst
Unread 18-03-2010, 02:19
FRC #1026
can i get it to do it for me? so I don't have to to worry about the penalty! I know that it will retract after I let go of the button but I want the cRIO to do it! Thanks
Unread 18-03-2010, 02:25
legendaryghost's Avatar
legendaryghost legendaryghost is offline
Legendary Ghost
AKA: Alex Goodwin
FRC #1922 (Team Oz-Ram)
legendaryghost is an unknown quantity at this point
The easiest way to get quick retracting on something like that would be to use surgical tubing or anything elastic and have it connected to the end of the piston to retract it. Surgical tubing isn't strong enough to cause any resistance against the piston either so you shouldn't lose any power. Good luck.
The Legendary Ghost
Unread 18-03-2010, 02:26
AKA: Jon
ok well you will need a sensor to tell the crio when its down for example a limit switch or what we are using which is a IR reciver/transmiter
and for legendaryghost his piston retracts fast enough but he wants it to do it automatically after he kicks
Unread 18-03-2010, 02:29
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You can do what he wants without a sensor. Automatically retracting a cylinder a certain time after it is extended can be done with no external feedback.
The code is a little bit complex, it's late and I have other things to do before I go to bed, so unfortunately I won't be much help, but it can be done.
Unread 18-03-2010, 02:30
FRC #1026
exactly! ok so do I just follow the examples in the LABview "piston with limit switch" or something like that.?
Unread 18-03-2010, 02:32
FRC #1026
I understand! thanks for your help on the joysticks!!
Unread 18-03-2010, 03:12
AKA: Jon
Talking Re: Retracting cylinder after kicking
here is a auto bring up for your kicker remember to repush it to kick again
replace the button status with the button 3 unbundle and the solenoid set with the solenoid set vi
Unread 18-03-2010, 12:55
FRC #1026
I appreciate all the help! I really do. But what is in this .vi? It looks like something I would use with the gyro. it has rotate to target, axis(x,y) is this what you meant to send me?
Unread 18-03-2010, 12:58
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
It appears to be a VI for mecanum drive control with the camera. Pretty sure that's not what they meant to post....(perhaps a better file naming scheme might help)
Unread 18-03-2010, 12:59
FRC #1026
that's what I thought! Thanks
Unread 18-03-2010, 17:11
AKA: Jon
sorry i put up the wrong one here
Unread 18-03-2010, 18:59
FRC #1026
Thanks man I thought that is what happened
Unread 18-03-2010, 19:09
AKA: Jon
did you get every thing that you wanted?
How to automate between extending and retracting of cyinders I am error NI LabVIEW 5 08-03-2010 00:20
Kicking Clarification??? K Lenox Rules/Strategy 17 21-02-2010 21:21
Retracting a cylinder? greatman05 Pneumatics 5 11-02-2010 15:24
Retracting power wiring ? mdatkins Electrical 5 09-02-2005 07:50
Life After Dean: Who Will Lead FIRST After Kamen and Flowers?? Joe Matt General Forum 25 24-06-2002 00:12
