Go to Post Smells like gracious professionalism in here... :) - marshall [more]
Unread 18-03-2010, 09:20
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: Fuse Help
We are using a 40amp for the compressor spike it pops any other ones
Every day is a new adventure!!!
Unread 18-03-2010, 09:26
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: Fuse Help
That's not legal (emphasis mine)
R60F. The fuse on the Spike relays may be replaced with a 20 Amp Snap-Action circuit breaker.
Unread 18-03-2010, 09:41
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: Fuse Help
We did and they didnt call it so they must one not care or two it is ok, We couldent get it to run a 20 with out kicking out so that was our fix.
Unread 18-03-2010, 09:47
Chris is me's Avatar
AKA: Pinecone
Re: Fuse Help
Woo, you got away with breaking the rules unintentionally. That doesn't mean it's legal. Please make an effort to fix it.
Unread 18-03-2010, 10:12
Re: Fuse Help
Try using a different 20 Amp breaker; they are kinda funny the way that they handle peak loads and maybe it just wasn't sitting right. The compressor draws high power at start up but shouldn't be drawing high power continuously - remember there is also a 20 amp breaker on the PD Board to the Spike. Check your complete wiring circuit - fix the problem, not the symptom (which is the breaker popping).
I just saw your post Brian - it didn't occur to me that the 40 amp breaker wouldn't fit (duh). It must be a 40 amp fuse.
Unread 21-03-2010, 10:14
Re: Fuse Help
It is hard to tell from the posts but it appears the fuse on the Spike is blowing. If you replaced it with a 40 amp fuse and it still blows, you have other issues. There is a short in the compressor or your wiring. Often teams get the compressor wiring under the compressor or wrap it around the "head". Under means the wiring gets clamped during compressor run since the compressor is vibration prone especially if not mounted properly. Around the head, the compressor gets really hot and likely can melt through the wiring.
If you are simply blowing 20 amp fuses in this application then that is normal. The 20 amp fuse in the Spike is guaranteed to blow when running the compressor. Start current is 25 amps while run current is 10-12 amps. Replace with a 20 amp breaker.
Electrical Engineer
Rookie Year: 1995
Re: Fuse Help
You need a 20A feeding the Spike and a 20A installed in the Spike. It is not an issue of getting caught by your inspectors. It is a safety issue. The Spike is only rated at 20A.
instead of using a bigger CB, investigate why it is tripping. You have a shorted wire or a bad compressor. It needs to be fixed.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 18-03-2010, 10:09
The Lucas's Avatar
Happy Birthday! The Lucas The Lucas is offline
CaMOElot, it is a silly place
Re: Fuse Help
Is it a 40A fuse or 40A circuit breaker.
If it is a 40A fuse (red automotive) replace it with a 20A circuit breaker
If it if a 40 A circuit breaker, first of all how did you fit it into the Spike? Replace it with a 20A breaker.
The compressor will work with a 20A circuit breaker. Even if it does trip momentarily the breaker will reset and it will work. If it doesnt work then your compressor may be bad or it is mounted somewhere with insufficient shock absorbing. I suspect you are using a 40A fuse and replacing it with a breaker is better anyway. Hopefully you can get it fixed tonight before you need to go through inspection.
Robot Inspector
Spike fuse JanTM1191 Electrical 3 31-01-2008 23:02
Help with understanding Fuse panel Blue_Midnight Electrical 3 10-02-2004 23:12
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Need RC Fuse Yan Wang Electrical 3 03-02-2003 22:06
Fuse Panels punarhero Electrical 5 18-02-2002 10:52
