Go to Post i have a feeling that the field with be the same as it was last year just to save some money. but what is inside the the field will be diferent. - Michael Leicht [more]
Unread 18-03-2010, 17:02
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: The 469 auto
Originally Posted by Chris is me View Post
That's a distinctly different situation, where a second robot consciously decides to enter the zone after the first is e-stopped. If 469 pushes someone through a tunnel, that's completely different.
Actually, it was the 2nd that enters the zone then e-stops. but that's not my point. The rules say that you need to show EFFORT to leave, or get a red card. If you can't go under the tunnel because 469 is blocking it, make an attempt to clear the bump. If you flip trying to get over the bump, your partner in the zone better try to show that effort because not even an E-Stop protects you from that. 2 robots flipped in the far zone after attempts to leave most likely would not incur any penalties since the original one was forced by 469
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Using auto cad for the autodesk inventor competition [527]phil Inventor 7 18-01-2006 10:41
Creater of the DeLorean auto dies Jay H 237 Chit-Chat 4 23-03-2005 12:54
Ruling for what defines being at the auto-loader Andrew Schuetze Rules/Strategy 4 15-01-2005 22:41
Team 469 and the Gyro archiver 2001 0 24-06-2002 02:57
Team 469 is the coolest!!! yystickers Off-Season Events 0 19-11-2001 14:51
