Go to Post When you are at the regional no one cares if you are a rookie. You are a part of the family. - scitecteach [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 18-03-2010, 13:30
Caleigh C Caleigh C is offline
None #2523
Caleigh C is an unknown quantity at this point
Password Login Troubles - WGA600N
We can't log in to our WGA600N wireless adapter. We tried resetting it and that's when the problems really began: we can't use the default password for some reason. (Either that or we have got the wrong one.) Can anybody tell us the default login settings? Or have any advice for us? We tried 'admin' and 'admin', respectively. Thanks for your help.
Unread 18-03-2010, 13:58
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Password Login Troubles - WGA600N
In my experience most wireless adapters tend to default passwords to:
admin
administrator
password
<blank> (that is enter nothing in the field and hit enter)
So I would try leaving the user as admin and <blank> or "password" as the password.
I don't have our adapter handy to check it though.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 18-03-2010, 14:33
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
According to the FRC 2010 Control System Chapter 3, you are using the correct username/password (see section 2.10.1).
However, you also want to make sure you hold down the reset button for several seconds to insure the unit is reset.
Hope this helps.
"The person who says it cannot be done should not interrupt the person doing it."
- Chinese Proverb
Unread 18-03-2010, 17:46
PinionTwister PinionTwister is offline
FRC #0269 (Cooney Tech)
PinionTwister is on a distinguished road
If you did a factory reset to the gaming adapter, the default IP address becomes 192.168.1.250
You will need to set a static IP on your machine to something like
192.168.1.10 / 255.255.255.0
admin / admin is the default username and password.
here is a reference to a user manual for the WGA600N - look to page 8 for connecting from a computer.
http://static.compusa.com/pdf/Linksy...00N-manual.pdf
Good luck - Dave G.
Unread 18-03-2010, 17:49
Also,
you may want to reset the gaming adapter again - hold reset button for 5 seconds or so....
Unread 18-03-2010, 20:36
Spartacus Spartacus is offline
FRC #2375
Spartacus is an unknown quantity at this point
We had luck reprogramming the WGA600N by:
resetting the 600N by holding down the button for ~10 secs (an orange light will start flashing after the reset has taken hold)
instead of running through a hub, we used a direct link via crossover enet cable between the 600N and the computer
set the computer IP to 192.168.1.2 mask 255.0.0.0
use a browser to navigate to 192.168.1.250
now you should see the WGA600N in your browser so you can set it up per the instructions...
WGA600N/WRT160N intermittent connection issues? andrew_3205 FRC Control System 5 01-02-2010 13:41
LINKSYS WGA600N no longer avilable sbrumund FRC Control System 2 27-01-2010 01:41
WGA600N on Woot Today EricVanWyk General Forum 1 20-09-2009 14:10
Automatic setup of the WGA600N (robot radio bridge) eugenebrooks Programming 2 06-08-2009 18:46
Security of WPA key on WGA600N eugenebrooks Control System 1 25-02-2009 01:10
