Go to Post Kyle from team 45 said "Dude, I still have 2 years left in FIRST ahahaha.." My response to that was... "Kyle, I have till the day I die." - Arefin Bari [more]
Unread 18-03-2010, 18:38
eedo369 eedo369 is offline
FRC #3088 (Kill-O-Bites)
eedo369 is an unknown quantity at this point
What is a Cypress?
Hello everyone,
I know this may sound a bit too late but I wanted to ask what exactly is the Cypress, what can I do with it and how does it work?
Unread 18-03-2010, 19:19
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Re: What is a Cypress?
Well here in the south, a cypress is a tree that grows in the swamp. But I doubt that is what you mean.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 18-03-2010, 19:27
The Lucas's Avatar
CaMOElot, it is a silly place
It is an electronic board that came in your KOP, also called a PSoC. You can connect it to the USB port of your Classmate and configure what I/O options you want. Then then you can program your cRIO to can read analog and digital I/O from switches etc, connected to the Cypress
Robot Inspector
Unread 18-03-2010, 19:28
Electrical Engineer
Rookie Year: 1995
You can read more about it here.
Mike Betts
As easy as 355/113...
Unread 18-03-2010, 19:34
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
There is a nice enclosure for the board which you can get here, if you would like a protective box and nice headers to wire to.
Unread 18-03-2010, 20:58
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
You can do cool things like put switches on it to tell the robot which zone it is starting in so it can use the right autonomous code......that is if there is time to program different autonomous
Rob Self-
Cyberhawks Team 706
Hartland, WI
Our breakaway bot in action (13-3-1): Team 706 in action
Unread 18-03-2010, 21:44
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
You can do more than that - You can build a whole custom control box for your operator (although I recommend against using it for the driver, simply because the driver needs two joysticks or a gamepad to drive)
Kettering Motorsports
Unread 19-03-2010, 01:00
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
You can have joysticks on the PSoC since its got ADC capability. You just have to use joysticks similar to the ones included in the kit 2008 and earlier.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 19-03-2010, 05:53
Thanks for all the info!
Can you tell me how to program it and and how to use Labview to program the CRIO to read it?
Unread 19-03-2010, 13:43
apalrd's Avatar
More Torque!
VRC #3333
To program the PSoC: Plug it in to USB (no battery needed) and open PSoC programmer. Find the file called FRC_IO_v2.hex, located in Shared Documents on the Classmate. Upload the image.
On the other end - Go to WPI Robotics Library => Driver Station => Extended IO for the extended IO. This includes VI's to read analog channels, digital channels, and write digital outputs, plus much more.
Unread 19-03-2010, 14:05
O.K. Let's say that I want to use the Button on the Cypress to determine which autonomous I want to use right before the match starts.
How do I do that?
The problam is, I don't know how to "connect" what I see in Labview to what I see on the board. And our electrician hasn't got a clue on how to connect DIOs and PWMs etc to it.
Unread 19-03-2010, 14:47
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
How do I do that?
For autonomous you can also use a few switches on the robot, connected to Digital Inputs. Or we use a rotary switch, with multiple resisters connected to an analog input on the robot.
To wire a few toggle switches on the control panel, we found it easier to take apart a joystick and parallel toggle switches to some of the push-buttons.
Unread 19-03-2010, 14:54
These are cool ideas, but I want to specifically use the Cypress because I want to understand how it works.
I'm the programmer of my team and I had almost no problams writing our code in Labview, including state machines, clusters, etc.
The problam is that as far as I can see, the Cypress requires both knowledge in programming and in electricity, and I can't write any VI without knowing how to 'read' it properly and maximize its potential.
Unread 19-03-2010, 18:03
apalrd's Avatar
More Torque!
VRC #3333
Once it is wired, its simple. Go to the FIRST control system documentation page and find a pinout of the Cypress IO board. Depending on what you want, you can use Compatibility or Enhanced IO. I used Enhanced, but Compatibility allows Virtual IO if you would rather have that. On your Classmate, you can configure if any digital input is pulled high, pulled low, floating, or out. You will want "pulled high" for all of the input/output you use, so the electrical team can wire between the signal and GND. In software, all pulled high inputs will be TRUE until the button is pressed, so NOT gates will become your friend. For analog Inputs, voltage in will be between 0v and 3.3v, or you can use the "analog range" for 0-1. There are also more advanced features, like two quadrature encoders on four inputs and some even more advanced IO on the Wireless connector (two DAC's, PWM Out, HDDIO, etc. ) and you can also use the buttons , LED's, 3-axis accelerometer, and touch slider on the board itself. It's all in "Enhanced IO". One thing you might find useful is the front panel. You can just put an indicator on all of the Cypress IO of the category you want and see what it does.
Unread 19-03-2010, 18:12
You make it sound so simple, but I guess you're right. The best thing to do is to just check it out myself.
I'll see what I can do next time I'll be near the CRIO.
Thanks!
Cypress Board Source lynca FRC Control System 1 03-02-2010 01:32
Cypress Board Issues kgzak FRC Control System 4 02-02-2010 18:40
Cypress board LAYOUT SteveD FRC Control System 11 23-01-2010 11:23
Cypress board bls0620 Electrical 4 17-01-2010 23:22
Cypress soc? sp33chy FRC Control System 2 15-01-2010 08:58
