Go to Post ...remember, this is coming from someone that spent the better part of an afternoon playing with an omniwheel--not assembling, not disassembling, just playing. - Billfred [more]
Unread 18-03-2010, 19:20
team_1026 team_1026 is offline
FRC #1026
team_1026 is an unknown quantity at this point
Re: Retracting cylinder after kicking
Well once I try that vi I will let you know. The only thing left is the camera! I bought a new camera that isn't an axis because we couldn't find ours. I don't know what all I have to change in order to make it work.
Unread 18-03-2010, 19:43
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
I'm not sure if this will help, but for us with c++, I just use the periodic checkup on buttons to determine if "button X" is pressed. If it is, the solenoid output is set to true, otherwise it resets to false if the button doesn't remain pressed.
As it is a one input, two output solenoid, this should work if set up similiarly in LabView. The solenoid always outputs to one side if it's pressurized, the true/false power only decides which side it pressures. It might help your team if you communicated with the mechanical division a bit more on how the gear works.
Unread 18-03-2010, 21:37
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
The kicker they have is a piston but he wanted it to retract automatically after a certain amount of time weather or not the button was still pressed so they wouldn't get a penalty
and it depends on what type of camera it is the c-rio will only work with certain types
Expect the best, Prepare for the worst
How to automate between extending and retracting of cyinders I am error NI LabVIEW 5 08-03-2010 00:20
Kicking Clarification??? K Lenox Rules/Strategy 17 21-02-2010 21:21
Retracting a cylinder? greatman05 Pneumatics 5 11-02-2010 15:24
Retracting power wiring ? mdatkins Electrical 5 09-02-2005 07:50
Life After Dean: Who Will Lead FIRST After Kamen and Flowers?? Joe Matt General Forum 25 24-06-2002 00:12
