Re: Scoring System Problems
The system is supposed to be backed up every now and again--usually during longish breaks (like lunch). If it did crash like that, most of the data would most likely survive.
As a reminder if you don't already do so at the event thank your head ref, scorekeeper, fta and ftaa. they're the ones that take a beating when the field malfunctions and do their best to make sure every team plays with in the rule book limits up until its beyond our control. here here lead position roles at the events *raises glass of mountain dew* |
It wasn't exactly a technical problem, but at the TC Regional there were penalties like crazy! The max seeding points from the #1 seed was like high 80s low 90s. They called the 3 inch infraction penalty everytime it went under a robot. Even if you tried to get it out, they still called it on you.
We also had alot of problems at TC with the scoring system. One time, the system stopped working, and they had to manually tally the points. We were scoring goals the whole entire match, and it was a penalty free match. They called the final score 2-2. One of our leaders went over and had a chat with the refs, like she does best. ![]() |
| scoring problems | GBilletdeaux930 | General Forum | 22 | 26-03-2008 23:52 |
| 2005 Scoring System | ttedrow | Regional Competitions | 4 | 24-03-2005 13:27 |
| New Scoring System | archiver | 2000 | 2 | 23-06-2002 22:22 |
| Scoring system. | Joel J | Technical Discussion | 7 | 13-06-2001 18:10 |
