Go to Post This web site is a service by our team to the FIRST Community to foster interest and growth in Engineering, the FIRST Competition and Education of youth for the careers of tomorrow. - Mike Martus [more]
Unread 19-03-2010, 08:21
ProgramLuke's Avatar
ProgramLuke ProgramLuke is offline
Captain
AKA: Luke
FRC #2169 (KING TeC)
ProgramLuke is an unknown quantity at this point
[FTC]: Infared
It should be noted that there is variation from one sensor to another as well as from one Beacon to another. A calibration routine to compensate for these differences is highly recommended when using the Beacon intensity for determining distance to Beacon.
How do I run a calibration routine in Labview?
2012 Inaugural Minnesota State High School League State Champions
2012 Galileo Division Semifinalists
2012 Wisconsin Regional Finalists
2012 Wisconsin Regional Entrepreneurship Award
2012 Lake Superior Regional Chairman's Award
2012 Lake Superior Regional Champion
2012 Lake Superior Innovation in Control
2011 Championship Imagery Award
2011 Championship Archimedes Quarterfinalist
2011 Minnesota 10000 Lakes Finalists
2011 Lake Superior Regional Chairman's Award
2011 Lake Superior Finalists
2010 FTC World Championship Finalist
2010 FTC World Championship Edison Division Champion
2010 Minnesota 10000 Lakes Regional Chairman's Award
2009 Minnesota North Star Regional Chairman's Award
2008 Wisconsin Regional Finalist
2007 Wisconsin Regional Champion
Unread 21-03-2010, 12:44
buddyb's Avatar
buddyb buddyb is offline
FRC #1885 (ILITE)
buddyb has a spectacular aura aboutbuddyb has a spectacular aura aboutbuddyb has a spectacular aura about
Re: [FTC]: Infared
My knowledge is limited, as I use RobotC, but I believe that the calibration routine must be made manually. I suggest that you just use a file to put the intensity from two different (predetermined) distances from the beacon. You can then use those readings in teleop (assuming the calibration was done in autonomous).
The best way to get the readings, in my opinion, would be to just slam in to the lower goal, get a reading, then go backward in to the wall, and get a reading. If you don't want to do this, you could even just get a reading while the robot is waiting to start autonomous. It would be a bit less accurate (read: one datapoint instead of two), but would still work.
For calculating distances, assuming that intensity/distance graph is linear, your equation is:
intensity[calibration]/dist[calibration]=intensity[current]/dist[current].
From this, you can do:
dist[current] = dist[calibration] * (intensity[current] / intensity[calibration])
If you did more than one calibration measurement, get an average of all of the readings and store that in the [calibration] variables.
Best of luck.
FRC - Team 1885 - Programmer.
Infared Sensor JohnFogarty Programming 0 02-03-2010 10:42
Infared in Next Year's Game Paradox1350 Rumor Mill 45 02-04-2004 20:45
Infared sensors???? Devastater Kit & Additional Hardware 1 21-02-2004 19:39
Infared Code TommyT Programming 1 11-01-2004 19:33
Infared Sensors on the field? Allison K Rules/Strategy 4 10-01-2004 20:42
