Go to Post I don't think that FIRST is going to get better with a top down solution alone, it is going to take a grass roots effort to strengthen teams. That starts by teams getting off their "islands", self imposed or otherwise. - Fe_Will [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 30-01-2010, 12:55
Akademee Akademee is offline
FRC #0888
Akademee is an unknown quantity at this point
Open AutoDesk files in SolidWorks
Hello Chief Delphi,
My task for this season is to CAD our robot in SolidWorks, however, I have been unable to locate a contiguous 2010 kop for SolidWorks. I know that there is the 3D Content Central, except out of the hundreds of files there are, I cannot seem to download it in one package. I also know that ProE files can be immediately called up in SolidWorks, but every single part file from the ProE directory needs to be extracted one by one by hand and has become very impractical as there are hundreds of files.
However, I was able to fully download and extract very good looking parts from the AutoDesk Directory. I need to know if there is a way to open these parts in SolidWorks. When ever I attempt to alter any "Options" in the "Open" menu, it only leads to SolidWorks, in essence, becoming disabled and will not perform any other functions as it says the program is busy. If there is a converter or any other "options" settings that need to be changed, I would really appreciate any help with this issue and I can get this robot designed.
Thanks Chief Delphi!
Unread 30-01-2010, 13:56
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Open AutoDesk files in SolidWorks
You might find something helpful in this collection of AutoDesk tools
http://students.autodesk.com/
Or from something like the FBX to/from Collada (and other formats) tool here (rummage around in the rest of the site to see what you can find).
http://usa.autodesk.com/adsk/servlet...12&id=10775855
I'm pretty sure you want to accomplish this without diving too deeply into Inventor and the rest of the Autodesk products, so I'm guessing these two suggestions are long shots; but maybe you will get lucky.
Blake
Unread 30-01-2010, 15:05
FRC #0888
Thanks for the help Blake, unfortunately I was not able to come to any results. I was recently told that AutoDesk and SolidWorks use relatively the same model types and therefore I should only need to change a few settings for opening the files and they will run fine, is this accurate?
Unread 30-01-2010, 17:20
The most trafficked CAD site available to FIRST teams is now the EWCP library, sponsored by Solidworks.
If you cannot find what you need there, send myself or user R.C. a part request and we'll see what we can do.
http://team1323.com/cad/index.html
Unread 30-01-2010, 18:27
FRC #0888
I think I just died and went to heaven!
Thank you so much Akash!
Unread 31-01-2010, 13:27
FRC #0888
This site is absolutely wonderful, but when I attempt to open a part in SolidWorks, it says that it is a future version and cannot be opened. FIRST gave us SolidWorks 2008-2009 and I know for a fact that SolidWorks is not backwards compatible, is there anything else that can be done?
Unread 31-01-2010, 14:42
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Download the step and drag and drop into Solidworks.
-RC
R.C.
MadTown Robotics Team 1323
Unread 19-03-2010, 09:35
FRC #0888
I am having trouble with opening both .stp files and .igs files in Solidworks. This worries me very much as before I was able to open .stp files in the program. Whenever I try to open a .stp file, I get a dialogue error box that says the file is either missing or invalid, among other things of similar meaning.
I have gone to both the Solidworks-sponsored site as well as the one suggested to me earlier and no files seem to work.
I can even open the Solidworks files that come from the site as well, yet ones that I have created my self still work fine. Should I begin to assume the worst with my solidworks program?
Thanks everybody,
Akademee
Unread 19-03-2010, 09:40
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Did you mean "I can't"? If that's the case, I would be suspicious that Solidworks is doing something funny, in which case a re-install (or the "repair" utility) might fix it.
However, it is conceivable that the .igs/.stp files you're opening are genuinely corrupt. If that's the case, you need to get non-corrupt versions of those files.
EDIT: One other thing, which version of Solidworks are you using? If you're using SW08 and the site's giving you SW10 files, then it is unlikely that you would be able to open them.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 19-03-2010, 09:58
FRC #0888
I apologize for the typo, I did mean to say "I can't." The other Solidworks files didn't concern me too much as I am aware that Solidworks possesses no backwards compatibility. However, I have always been able to open and access ,stp file types without any problems. I have not had a reason in the past to reinstall or repair Solidworks, what do I have to run in order to get to the "repair" function, I would assume the installation wizard.
It is interesting how you mentioned that the files themselves could be corrupted. I am working on another project that needed a rather large bearing and I went to McMaster-Carr and I was able to receive a solidworks CAD file of exactly what I wanted and it went into the assembly with no problem at all. Is it probable that the .stp files from both sites are corrupted?
If it is worth mentioning; to my knowledge, my Solidworks 2008-2009 has not downloaded and installed any recent updates.
Thanks,
Akademee
Unread 19-03-2010, 10:02
AKA: Jimmy Cao
It's conceivable that the .stp files from your 2 sources share a common origin, in which case I wouldn't be surprised if they're both bad.
I believe the repair utility can be accessed via either 1) Add/Remove program menu (control panel, it'll probably ask for your SW DVD), or 2) The setup program on the SW DVD (forgot what it's called). When prompted, pick repair instead of remove.
Good luck.
Jimmy Cao
Unread 19-03-2010, 10:10
FRC #0888
Thank you for the tips, I will try them very soon
Thanks,
Akademee
Unread 21-03-2010, 16:01
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
If you need a copy of the SolidWorks Student Edition for 2009-2010, please go to www.solidworks.com/sponsoredDesignContest.
Marie
Unread 21-03-2010, 20:05
FRC #0888
Thanks, I repaired Solidworks and it seems to be working fine, I did find something interesting though, I am not sure if this should be worth noting as a bit of an FYI, but I found that Solidworks can open an .stp file as a part, however it cannot insert an .stp file into an assembly. I had to save the .stp as a Solidworks part before I could insert it into my assembly.
Thanks for your help everyone!
Akademee
Unread 21-03-2010, 20:47
AKA: Jimmy Cao
Akademee
Glad it worked out!
When Solidworks opens a .stp file, it doesn't just "open" the file as is. It generates a .sldprt (or a .sldasm and a few .sldprts). You'd need to save those files before you can insert into an assembly. Its just a feature of the software; I think all CAD platforms behave similarly.
Jimmy Cao
Solidworks KOP files nittemare SolidWorks 7 15-01-2012 18:00
Call up Pro/E files in SolidWorks TroyCDH SolidWorks 1 12-01-2010 19:29
Is it possible too import the Auodesk Files to Solidworks? vmuralidharan Inventor 2 10-01-2009 14:41
How to create 3D dxf files in Solidworks, Inventor, or other? Travis Covington SolidWorks 6 03-05-2006 21:46
Solidworks Files Panther378 Technical Discussion 1 21-01-2006 22:34
