Re: "Failed to load shared library FRC_UserProgram.out on RT target device"
I'd fix your permanent download problem first. Without that nothing else matters.
Perhaps describe the steps you take in detail to download, including any and all settings you've made in properties. Try not to use the term "latest." Use the real version #'s. I hear "latest" so many times at regionals, and it just means the last version they noticed... |
| Anyone made use of the "Call Library Node"? | gvarndell | NI LabVIEW | 2 | 23-02-2010 20:15 |
| Windows "Malfunctioning USB Device" error with Psoc IO Board | WarrenPW | FRC Control System | 2 | 11-02-2010 18:53 |
| "code doesn't load" solution C++ | whatabouteve | C/C++ | 2 | 09-02-2010 17:04 |
| "Signaling Device" reciever location? | FreakyAntelope | General Forum | 9 | 06-01-2008 01:50 |
| Camera never finds target, stays at "Searching..." | Mike | Programming | 12 | 22-01-2006 12:47 |
