Go to Post We should have a 'Steps Taken For FIRST' contest. Everyone wear a pedometer and keep a log of how many miles you walked at the St. Louis Championship. That could be a lot of fun. Do they make pedometers for robot carts? - JaneYoung [more]
Unread 19-03-2010, 00:32
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Scoring System Problems
Lets just hope it doesn't try to pull a divide by zero on us and suffer an unrecoverable crash {e.g. dumps all memory accumulated from the previous day or two of quals and all the QP's and cooperation bonuses, etc.}.
Unread 19-03-2010, 01:49
The system is supposed to be backed up every now and again--usually during longish breaks (like lunch). If it did crash like that, most of the data would most likely survive.
Unread 19-03-2010, 03:49
DCA Fan's Avatar
DCA Fan DCA Fan is offline
FRC 812/3476 Mentor
AKA: George
FRC #0812 (Midnight Mechanics)
DCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond repute
In San Diego I believe we had two matches in which the computer score did not match what we observed on the field; our sharp-eyed referees quickly caught and corrected the problem.
2016 FRC Orange County Regional Co-Chair, FRC San Diego Emcee, FRC Ventura Emcee, Vex Worlds Emcee
2015 FRC Emcee: Inland Empire, San Diego, World Championship. VRC Emcee World Championship
2013-2016 FLL Judge Advisor, Southern California/Legoland
2001-2005 FRC294 Beach Cities Robotics
2005-Present FRC812 Midnight Mechanics
2012, 2014 FRC3476 Code Orange
2003-Present Volunteer, FRC/FTC/FLL/VRC
NEMO | San Diego Regional | Orange County Regional | FIRST California
Unread 19-03-2010, 06:29
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by JBotAlan View Post
This is perhaps the most perplexing of the field faults for me, mostly because I have a hard time wrapping my mind around how you mess this up.
Does anyone know of a legitimate reason the real-time score should ever be negative? The rules have always been pretty clear on the issue of negative scores...granted, the rule says "Final score" but I still think that displaying a negative score does nothing but cause confusion.
Jacob
There apparently are two versions of the score system. At least at some locations in Week 1, DOGMA penalties were decremented from the score as they happened. I saw a -3 score on the display at Kettering.
I understand that other events reported the DOGMA penalties after the match, which also caused confusion. The referee would confirm the score, the announcer would say, "No penalties" - and then there were 3 penalties appearing on the screen. Only the scorekeeper could see the DOGMA penalties separately.
(since 2004)
Unread 19-03-2010, 09:27
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
I don't think this is the case. During testing of the field at Traverse City, we found that the DOGMA penalties were not added in real-time, but rather in one big chunk at the end.
However, there is a penalty that can cause negative score. The scoring sensor work on the quadrature principle. In theory, it can detect the difference between ball-in and ball-out. In practice, it's only 99% correct. Every now and then, you have a ball-in counted as a ball-out, which is assessed a 2 point penalty (in real-time). A score of -3 means 3 balls were scored, 1 was scored "in", and 2 were scored "out" (or any # of scenarios where you get similar scores). I saw this happen at Cass Tech as well, when a team that had 7 points dropped to 5, instead of going up to 8, when they scored.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 19-03-2010, 12:18
Mark Holschuh's Avatar
Mark Holschuh Mark Holschuh is offline
FRC #2194 (Fondy Fire)
Mark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud of
At the Wisconsin Regional there was at least one incidence in an early match in which a ball bounced in and partially back out of the goal counter, so that it counted two balls as being scored. However, only one ball was returned to the field. That alliance ended up losing due to the autmated DOGMA penalties.
They appealed, but were told that the final score was official. But the field crew used manual scoring for the remainder of the regional.
As a result, the real-time scoring was often not correct.
Unread 19-03-2010, 12:31
O-H
FRC #0048 (Delphi E.L.I.T.E.)
So what do people think of the blue side of the field failing/miscounting/deleting realtime scores on multiple fields? It seems to be happening at Midwest, and blue was definitely was the preferred color of fail at Pittsburgh.
Unread 20-03-2010, 00:55
kylelanman's Avatar
kylelanman kylelanman is online now
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
I know the blue side was faulty at WI and someone said in another thread the same field that was in WI is now at Midwest. As for Pittsburgh I have no clue.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 20-03-2010, 03:06
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
At one of our matches we got 44 DOGMA penalties
A video reply (and about a dozen unrelated eye-witnesses) confirmed that indeed all balls were brought back into play in the correct time and manner.
We didn't even try showing the ref (Go Stu!) the video since I knew it was not admissable as evidence .
The match was entered into the system as-is, 44 penalties and all. and my team took it in stride: joking about setting a new world record in FIRST...
In the end that match was scrubbed when team captains voted to scrub all day 2 matches and start over on day 3 due to the communication problems that plagued our regional.
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
If you want the honest end of backups, it's usually after each match (providing there's an internet connection b/c it uploads directly to where you see the scores and what not on FIRST's site), and then usually manually backed up lunch then at the end of the day / event. FMS backs up pretty regular w/o any user telling it to do so just in case of such a problem or worse. The way the system is designed and programmed isn't bad at all but the time frame to acct. for EVERYTHING and ANYTHING that COULD happen is extremely slim.
As a reminder if you don't already do so at the event thank your head ref, scorekeeper, fta and ftaa. they're the ones that take a beating when the field malfunctions and do their best to make sure every team plays with in the rule book limits up until its beyond our control.
here here lead position roles at the events *raises glass of mountain dew*
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 28-04-2010, 08:19
Mop Iii Top's Avatar
Mop Iii Top Mop Iii Top is offline
AKA: T L
FRC #2645 (PowerSurge)
Mop Iii Top is an unknown quantity at this point
It wasn't exactly a technical problem, but at the TC Regional there were penalties like crazy! The max seeding points from the #1 seed was like high 80s low 90s. They called the 3 inch infraction penalty everytime it went under a robot. Even if you tried to get it out, they still called it on you.
We also had alot of problems at TC with the scoring system. One time, the system stopped working, and they had to manually tally the points. We were scoring goals the whole entire match, and it was a penalty free match. They called the final score 2-2. One of our leaders went over and had a chat with the refs, like she does best.
Power to the People!
PowerSurge
2010 FRC Robot A.K.A. The Enforcer.
scoring problems GBilletdeaux930 General Forum 22 26-03-2008 23:52
2005 Scoring System ttedrow Regional Competitions 4 24-03-2005 13:27
New Scoring System archiver 2000 2 23-06-2002 22:22
Scoring system. Joel J Technical Discussion 7 13-06-2001 18:10
