Go to Post Add a little more grease if you aren't sure exactly how much you need. - MrForbes [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 19-03-2010, 19:37
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Autonomous trouble
Been having some trouble with CAN jaguars during autonomous. Teleop works just fine, but in testing with the jags under CAN we can sometimes get autonomous movement and sometimes we can't.
When the jags don't move, either all of them blink yellow or all grey ones are solid but our black jag bridge is blinking. The moment teleop is enabled they all go to their normal lights.
I think it has something to do with our autonomous not sending constant commands to the jags, while teleop sets on every loop. However, I can't figure out why it sometimes works and sometimes doesn't. I can't think of anything that's changing between when it works and when it doesn't
We use C++, are using the 2nd release of the CANJaguar code from firstforge, and running v89 firmware. Don't have access to the robot or it's code right now
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 22-03-2010, 15:19
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Autonomous trouble
We've seen this issue also and ended up using a timer in a while loop to do Autonomous.
Trouble With Autonomous Camera Tracking whswrestler189 NI LabVIEW 5 21-01-2009 19:20
Trouble with Autonomous popnbrown Programming 15 27-02-2007 20:48
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
Has anyone else had trouble staying within the 10 second limit in autonomous? lkdjm Programming 18 12-02-2006 18:10
Autonomous Code trouble The yellowdart Programming 16 21-01-2006 10:36
