Re: XBOX Controller Triggers is an axis but which one?
True, though whatever serves the purpose is great as it doesn't matter how it is constructed.
-Tanner |
It its axis 3
It is axis number 3, and it defaults to value of 0.0 and goes negative when right trigger is down and goes positive when left trigger is down.
Go to control panel --> game controllers --> properties. It shows up what button and axis is what when you press it. We have everything except the rumble. There's some threads, I believe in WindRiver, for using rumble, but does any one know how to do it in Labview? I would love to be able to have it rumble when our robot senses a ball.+
#7
the default code and the DS software prevent writes to the joystick, so you would have to circumvent it using one of the methods above |
#8
Thanks for all your help I hope to try this out at Palmetto.
Just another quick Question. when I wired axis 3 into a True False Selector the true and False changed to 1 and 0 which i put my true code in 1, and my false code in 0. see attached pictures tell me if im doing this right. If the button is true then set the motor speed to the percentage of the button press, for variable control. If the button i...s false, then I made another true/false case for the sensor. In the false case, I set the motor speed to 0.1. In the true case, I set the motor speed to 0. This way, when the button is NOT being hit, it looks for the sensor, and it spins it around REALLY SLOWLY until the sensor is tripped, and then it stops there. ![]() and another ![]() |
#9
The problem with using the 0 and 1 cases is that it is possible that you cannot get to the 1 case if your XBox controller is out of calibration. If you use the 0.5 compare, you will be covered. |
#10
for a controller mapping of the xbox 360 controllers please see this post
http://www.chiefdelphi.com/forums/sh...3&postcount=12 |
| Xbox Controller | Team1710 | FRC Control System | 9 | 30-06-2010 13:17 |
| Which axis for accelerometer? | bitsoglass | NI LabVIEW | 1 | 23-01-2009 17:42 |
| Xbox Controller? | ScottieDo555 | Technical Discussion | 24 | 29-01-2008 16:24 |
| Which is better? (Xbox 360 or PS3) | 842.001 | Games/Trivia | 29 | 11-11-2006 16:06 |
| Do the Dew... but which one? | OneAngryDaisy | Chit-Chat | 13 | 16-06-2003 16:17 |
