Go to Post Nonetheless, I would welcome it, as long as [The President] didn't restrict the number of discs that a Robot could hold. Oops, wait, too late, the GDC already did that. :-) - MooreteP [more]
Unread 24-02-2010, 22:34
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
pic: 1751's 2010 robot hanging
Unread 24-02-2010, 22:35
CraigHickman
Posts: n/a
Re: pic: 1751's 2010 robot hanging
Cool tracks! What brand belts/pulleys are those? I'd love to see some closer shots of the drive base, as I always like to see different track implementations.
Unread 24-02-2010, 23:04
MIT '14
Brecoflex TK10-K13 with red linatex backing. I'm afraid we won't have better pictures until the Long Island regional.
There are two lowered center pulleys, giving a total ground contact of about 7" per side. Turning is wonderful. One end is the drive pulley; the other end has a sliding pulley for tension adjustment.
Unread 24-02-2010, 23:15
Racer26 Racer26 is offline
I knew I recognized those Brecoflex belts. We used similar ones on our tracks in 2007/2008. Anybody that saw our drives knew they were cool (transversely mounted CIMs (2, room for 3 because we were allowed 6 one year) inside the loop of the belt itself) 2 bolts and 4 wires, plus the encoder, were all that was required to change a whole unit should one fail.
Unread 24-02-2010, 23:53
CraigHickman
Posts: n/a
Good choice on belts! How did you address the side slipping problem?
Unread 25-02-2010, 00:55
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Cue Archie and Edith....
The belts have a self-tracking guide - you can see the v-groove in the idler pulley. http://www.brecoflex.com/index.php?CATID=7&SCATID=64
I'd ask for weight and cost, but then, I already know.
Unread 25-02-2010, 02:22
CraigHickman
Posts: n/a
Our team is using the same belts, and there is a definite side loading problem. The V groove in the middle isn't enough to stop the belt from being locked up (and breaking itself!) if the bot is pushed from the side, unless it can be addressed somehow. I was simple asking whether or not they had looked into the issue.
Unread 25-02-2010, 10:12
1075 had similar problems with snapping belts when side-loading them, we also had big problems with battery life, especially in the later iterations of our drivetrains (for FIRST Overdrive). This, and the fact that our modules were relatively heavy was one of the big reasons we moved away from it, first to a modularized 2 speed shifting 6wdDropCenter, and then in 2009 to our 2+2 swerve, and to our latest Drive train for 2010. This one is unlike anything I've ever seen before.
1625 has their 6 wheel swerve, and 148/217 have their nonadrive, both of which I love. 1075's bringing a new toy to Waterloo, GTR, Championships, KK11 and BE9. I can't wait to see what people will have to say about it.
Unread 25-02-2010, 14:52
MIT '14
In our testing, the side loading problem was not encountered. We geared our motors so that the stall torque was safely less than the belt's breaking force. Once the side load reaches about 150 pounds, the motors have difficulty moving the robot, but the belts still do not break.
In the competition, we'll try to enter only head-on pushing matches.
Dave
Unread 25-02-2010, 17:06
CraigHickman
Posts: n/a
Dave
Good strategy idea. In our testing, the Brecoflex belts didn't actually break when heavily side loaded, but rather began to delaminate. A solution that helped the problem was to bevel the corner of the belt (also made it turn better), as well as put flanges on all idler pulleys to keep the belt supported fully.
I'd love to see some videos of your team's matches once the regionals start, as it looks like you guys built a beast of a bot.
Unread 25-02-2010, 18:36
MIT '14
Beveling the belts is an interesting idea. What tool did you use do it? Our shop is not very well-stocked, so we would probably have to use a "belt" sander.
Unread 25-02-2010, 18:46
CraigHickman
Posts: n/a
I believe it was done with an angle grinder, but I'll have to ask the people who did it. I'll post back when I have an answer.
EDIT: Turns out they were custom ordered that way after the first few delammed.
Unread 27-02-2010, 11:23
MIT '14
We're ordering a set of spare belts from Brecoflex, potentially with the beveled backing. Do you by any chance have a close-up picture of the modified belts?
Unread 02-03-2010, 01:23
CraigHickman
Posts: n/a
Not personally, but I might be able to get my hands on one in a day or three. If I can I'll post it here.
Unread 20-03-2010, 01:53
Punkk242's Avatar
Punkk242 Punkk242 is offline
SBPLI Volunteer
AKA: Justin
FRC #1751 (The Harbingers)
Punkk242 is on a distinguished road
Send a message via AIM to Punkk242
Looks awesome David. Great Job!
BOOM HEADSHOT!
Team 1751's robot, stripped Punkk242 Robot Showcase 0 17-02-2007 19:39
pic: Our robot hanging. CD47-Bot Extra Discussion 5 07-04-2004 07:59
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
pic: Team 48 Robot Hanging CD47-Bot Robot Showcase 1 01-03-2004 20:22
pic: Cutting Edge's Robot hanging! CD47-Bot Extra Discussion 4 28-02-2004 23:14
