Go to Post Forum Anonymity = Rampant Exaggeration, if not outright Blatant Lying. - dsm [more]
Unread 20-03-2010, 11:06
tank drive mecanum algorithm
Here's a way to program tank drive on mecanum bot so that you can tune the joystick sensitivity to all three motions (fwd/rev, turn, stafe) independently:
Let Kf, Kt, and Ks be the tuning parameters (0 to +1) for the forward/reverse, turn, and strafe motions, respectively.
Let X1 and Y1 represent the joystick outputs for the driver's left-hand joystick;
Let X2 and Y2 represent the joystick outputs for the driver's right-hand joystick.
When each joystick is pushed forward, its Y output should be positive. When the joystick is pushed to the right, its X output should be positive. If not, add code to invert the sign if necessary.
Let W1, W2, W3, and W4 be the front left, front right, rear left, and rear right wheels, respectively. ("left" and "right" in this context means "port" and "starboard", respectively)
Calculate the following:
Yf = (Y1 + Y2)/2
Yt = (Y1 - Y2)/2
Now calculate the four wheel speed commands:
W1 = Kf*Yf + Kt*Yt + Ks*X1
W2 = Kf*Yf - Kt*Yt - Ks*X1
W3 = Kf*Yf + Kt*Yt - Ks*X1
W4 = Kf*Yf - Kt*Yt + Ks*X1
Now normalize the wheel speed commands:
Let Wmax be the maximum absolute of the four wheel speed commands. If Wmax is greater than 1, then divide each of the four wheel speed commands by Wmax.
Finally, send each of the four normalized wheel speed commands to the respective wheels.
Tank Drive vs. Omni Directional Drive jamie_1930 General Forum 9 24-01-2010 22:50
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
Tank Drive Sauce Programming 1 05-01-2009 18:50
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
