Go to Post A coin flip is a wonderful thing. Not because it makes the decision for you, but because when the coin is in the air, you realize what you really want. - rtfgnow [more]
Unread 20-03-2010, 20:19
Re: Autonomous independent-watchdog errors
Originally Posted by ewoodring View Post
I get error messages in the message window in the Diagnostics tab on the Driver Station that say "Watchdog expired: system #, user #." Is there anything in code I have to change to fix this?
It depends.
A few of these messages are normal and may not affect your robot operation.
The # is a count of how many of each have occurred and of which type of Watchdog (system vs. user).
  • You'll usually see momentary system Watchdogs at mode transistions, e.g., Disabled -> Auto -> Teleop -> Disabled. Those are nothing to worry about.
  • User Watchdogs are common when your autonomous code finishes and exits, but seeing them in Teleop or while Auto is supposed to be running is a problem in your code.
In the lower left of the Driver Station screen are you seeing a persistent message of "Watchdog not Fed?"
That message will occur if you are not currently running any autonomous code at all, for instance, if it has already completed and exited or if you have bypassed all auto code. The default Autonomous Independent will generate this Watchdog, since after it completes it's assignment it just exits and the Watchdog goes unfed.
The Watchdog message is not a problem if no code is supposed to be running.
In this case, when Teleop code begins to execute, it will resume feeding the Watchdog and the message will go away.
periodic tasks in autonomous independent Ether NI LabVIEW 19 31-03-2010 07:15
global variables and autonomous independent Team1824 NI LabVIEW 10 19-02-2010 23:00
Autonomous Mode, Independent, Iterative (?) FRC2669_Valery General Forum 4 18-02-2010 09:50
Autonomous Independent Code Issue Watchdog not fed pilum40 FRC Control System 0 11-02-2010 12:00
Using Sensors in Autonomous Independent Felipe Sagui NI LabVIEW 2 27-01-2009 17:25
