Go to Post I have always liked to see people get recognized for what they do, not people doing something to get recognized. - sanddrag [more]
Unread 20-03-2010, 22:24
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Re: pic: Soccor balls stuck on ball return
Originally Posted by The Cyborg View Post
Well, I found out today what the case was.
Apparently one of the teams had some sticky stuff on their gripper/kicker mechanism that managed to adhere to the ball, which caused the ball to slow down on the way down the ramp and get stuck in the space in between the ramp and the hanging pole on the tower (since the ball didn't have enough velocity to just simply bounce down). GooGone did the trick of getting rid of the sticky stuff on the ball .
This is correct.. I was working on the field and many teams were using duck tape on the front of there robots. We ended up rotating out 8 balls off the field, to help prevent this. Also, every team, that had something close to a sticky substance, was checked out to see if it was going to become an issue.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 20-03-2010, 23:14
The Cyborg's Avatar
The Cyborg The Cyborg is offline
That Awkward One
AKA: Mary Soltis
FRC #0051 (Wings of Fire)
The Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant future
I also think that the gaffing tape used to line the field might be leaving some residue on the balls, so this issue can't be completely avoidable. It's all a matter of checking for anything obstructive on the balls before the match. I encourage every team and volunteer to double check for things like this before the match, and notify someone before any problems arise. Otherwise we will need to gather up some 2006 pokey pokey sticks as Travis Hoffman mentioned earlier
Unread 21-03-2010, 17:12
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Travis Hoffman View Post
Someone should lash some 2006 pokey pokey sticks together and create the most entertaining volunteer position we've had since....the 2006 pokey pokey guy.
Gee, that seems like a kinda hokey solution.
That's what it's all about.
Ball Return Worries indubitably Rules/Strategy 12 07-03-2010 16:02
Ball Return Time GKrummel Rules/Strategy 1 16-01-2010 14:26
Ball Return frank.pendzich Rules/Strategy 11 11-01-2010 09:19
Balls getting stuck in hopper FTtyler General Forum 30 09-02-2006 20:57
Low Priced soccor balls mnkysp6353 General Forum 0 08-01-2002 20:58
