Go to Post I'm sure there are many people out there who check their rep screen every 20 minutes in hope of positive reinforcement in a unique community, where they may not get positive reinforcement for sharing information in their home, school, or robotics program. - Eugenia Gabrielov [more]
Unread 18-03-2010, 23:37
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Re: Digital Sidecar relay ports: correct voltage?
This Q&A more closely describes what we are doing with the electromagnet:
http://forums.usfirst.org/showthread.php?t=14279
Unread 18-03-2010, 23:56
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Yes, that's much more definative. Glad you found/received a clearer answer.
Phil Malone
http://www.GEARSinc.org
Unread 21-03-2010, 12:33
Originally Posted by PhilBot View Post
Wow, that's a pretty broad interpretation.
Electromagnets good, Solenoid Actuators Bad.
It's actually a narrow interpretation. A COTS electromagnet is clearly permitted as long as it is not actuating something. A COTS electro-magnetic actuator is not permitted under any circumstances.
Make sure you have a printout of that Q&A on hand at all times
I just hope you don't get a finicky EE as an inspector.
There could be some big arguments there......
The only thing that is not clear is whether a COTS electromagnet is permitted if it is actuating (forcibly moving) something external to itself on the robot. That specific question has not been explicitly addressed by GDC by either of the Q&A responses, since both questions were asking about an electromagnet simply holding something, not moving something.
There have been no arguments about electromagnets used as a holding device, that I am aware of. I don't expect any. The GDC ruling was quite unambiguous.
Unread 21-03-2010, 12:50
PhilBot's Avatar
AKA: Phil Malone
I'm not arguing the ruling... but if you really want to split hairs, how is holding something, and then letting go, NOT an actuator.
What is the purest definition of an "Actuator"?
Seriously, unless you are using the magnetic field to manipulate sub-atomic particles, isn't the whole point to effect the motion of another item... holding, or pushing, or pulling.... in all cases you are excerting a force on another object, causing it to either move, or not move. In the case under siscussion, if the electromagnet is on amd the metal is being "held" in place, and then some external force (robot) did pull the metal away from it, and then than force was removed, wouldn't the electromagnet pull the metal back into place again... So although it would "normally" be holding it in place it may actually move it under some unforseen operating circumstances.
So... holding or pulling or pushing.... seems to me it's an actuator no matter what it's doing. Fortunately the GDC has ruled otherwise... but it's far from "unambiguous" in my more "generic" view.
Phil Malone
Unread 21-03-2010, 13:39
I don't want to split hairs.
Just telling you what the GDC ruling is. The ruling was clearly that if you are using a COTS electromagnet to just hold something, and then let it go, it is legal. That much is quite clear. If you want to call that an actuator, I don't mind.
You may call it an actuator if you like. But other people may misunderstand you.
The GDC ruling is clear as far as how they have specifically permitted electromagnets to be used. Whether or not it is permitted to use an electromagnet in different contexts is a different question, as yet unresolved AFAIK.
Relay Ports on the Digital sidecar have no Power 10uhingp Electrical 6 30-01-2010 14:00
Attaching a standard car relay to the Digital sidecar KillerGardevoir Electrical 4 02-08-2009 21:26
Digital Sidecar Ports are dropping out. Tom Line Electrical 19 10-04-2009 00:55
Ultrasonic sensors on digital ports 3-6 problems wt200999 Programming 14 13-02-2008 08:13
LED's on Relay Ports? Kingofl337 Control System 5 18-01-2008 14:39
