Go to Post Let's not complain when we are getting magnificent items in the kit that teams just a few years ago could only wish for. - sanddrag [more]
Unread 21-03-2010, 15:58
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
pic: How to lift your robot safely
Unread 21-03-2010, 15:59
Squeakypig's Avatar
Squeakypig Squeakypig is offline
AKA: Mike Coyle
FRC #2851 (Crevolution)
Squeakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond repute
Re: pic: How to lift your robot safely
i can never understand how you guys hang, everytime i see it happen it happens in 2 seconds and i dont understand what just happened. Do you have a detailed explanation or perhaps, even better, a video?
Unread 21-03-2010, 16:15
FRC #0201 (FEDS)
I just posted a video of us hanging on youtube for your enjoyment
To hang we release our arm, and using break cable we release our hook. The hook is positioned against the horizontal bar, and when we start our winch, the hook falls off the arm and arm falls down. Then we winch ourselves up for 2 points
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Unread 21-03-2010, 16:42
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
great motion on your arm, I can see you put a lot of effort into making the deployment of your arm attach to the bar quickly. It certainly must make it easier on your drivers.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 21-03-2010, 16:47
FRC #0201 (FEDS)
It was definitely a long design process for the arm to get it right, but it payed off. Our base driver only has to line up in the general area of the tower, and with the pressing of 2 buttons we are in the air.
We were having problems with the arm at Kettering, but after switching our steel cable out for sailboat rope (I'm not sure the technical name), we can hang in 1/3 of the time, and it won't get tangled on the arm!
'08, '09, '10
Unread 21-03-2010, 17:20
raffi383 raffi383 is offline
Build Mentor
FRC #0201 (FEDS 201)
raffi383 is on a distinguished road
Here's a detailed explanation of how the arm works.
There is a gas strut that is attached to the lower portion of the arm. When a latch at the back end of the lower arm is released, the strut raises the lower portion of the arm.
When the lower arm is near its fully upright position, a cable attached to the robot and to the bottom end of the upper arm begins to tighten.
Once the lower arm is at its upright position, the cable attached to the upper arm is holding the upper arm in its fully extended position.
As the upper arm gets near its fully upright position, a second cable (bike brake cable) that is attached to the lower arm and a release hook that retains the hanging hook holder in its folded position is pulled and the hanging hook holder swings into position.
With the hanging hook over the tower bar, the winch is turned on. The kevlar line that we use to lift (instead of the original steel cable that looked like a screwed up pretzel after Kettering) is routed through another retention hook that holds the bottom of the gas strut in place. Since we didn't want to have the arm in the deployed position when lifting to avoid bending it and didn't want to have to compress the gas cylinder to bring the arm down, we just release the bottom end of the gas strut and it slides rearward which lets the arms drop.
The hanging hook is held to its holder by magnets. Once the gas strut retention hook is released and the arm begins to drop, the magnets disengage from the arm and the hook remains on the tower.
For resetting after the match, we have a clutch on the winch that we can pull out by hand so we can unwind the line from the pulley without power. There is also a ratchet on the winch to keep it from backdriving after we turn the power off. The gas strut is automatically reset when the arm is manually lifted to the extended position.
There is a lot of "magic" in our arm. It took a while to get it to work.
Hopefully we will be in Ypsi hanging around at the end of the Finals.
Stop by the pits for a demonstration.
Raffi
Unread 21-03-2010, 22:58
ExTexan's Avatar
ExTexan ExTexan is offline
Parent and Volunteer
AKA: Richard Singletary
FRC #0548
ExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant future
Tell Louis that is a great video, a very quick hook, hard to measure. See you at States!
THE HOOK!
What we think, or what we know, or what we believe is, in the end, of little consequence. The only consequence is what we do.
2010 REFEREE: Kettering, Ann Arbor, Wayne State, Troy, MI Championship, Atlanta-Newton field, IGVC TARDEC, MARC and upcoming KETTERING Kickoff.
How would you have built your team's robot differently if the robot could expand? Chris is me General Forum 23 23-04-2009 06:50
pic: 781 robot lift d.courtney Robot Showcase 8 21-02-2007 14:59
How does Your ramp/lift work? Cody Carey General Forum 3 14-02-2007 22:01
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
pic: How strong is your robot? PennRobot135 Robot Showcase 2 21-02-2005 12:50
